LibreDrive for Pioneer drives
Request for UD04 v1.14 UHD firmware for BDR-UD03 (RS8511)
I’m new to LibreDrive and would like to enable UHD on my Verbatim/LG-branded Pioneer slim drive.
Could someone please share the patched UD04 v1.14 firmware for my BDR-UD03?
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number:
Firmware date: 2018-11-28
Highest AACS version: 63
Drive platform: RS8511
Firmware version: 1.11
Revision: 1.11
Serial number:
Re: Request for UD04 v1.14 UHD firmware for BDR-UD03 (RS8511)
sure email me that infoAaexy wrote: ↑Thu Jun 26, 2025 2:13 amI’m new to LibreDrive and would like to enable UHD on my Verbatim/LG-branded Pioneer slim drive.
Revision: 1.11
Serial number:
perfektcom
This is my first post here.
I have the following drive:
OS device name: H:
Product: BD-RW BDR-208D
Revision: 1.50
Serial number: XXXXXXXXXXXXXXXXXX
Firmware date: 2015-09-24
Bus encryption flags: 13
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.50/ID61
Can it be flashed? If so, where can I get the firmware.
OS device name: H:
Revision: 1.50
perfektcom
I also have another drive (I believe this is a OEM of an Pioneer drive):
OS device name: E:
Manufacturer: hp
Product: BD-RE BU20N
Revision: BU24
Serial number: B5GS3P1013604
Firmware date: 2115-04-22 13:44
Bus encryption flags: 1F
Firmware version: 0.BU24P
OS device name: E:
Manufacturer: hp
Revision: BU24
Yes just email me that info belowperfektcom wrote: ↑Wed Jul 02, 2025 5:20 pmHi,
OS device name: H:
Revision: 1.50
Nah it's an LGperfektcom wrote: ↑Wed Jul 02, 2025 5:24 pmI also have another drive (I believe this is a OEM of an Pioneer drive):
OS device name: E:
Manufacturer: hp
Revision: BU24
bovidvkbs88
Hello all. I have a old PIONEER and I wanted to see if anyone can help me confirm if the FW Flash is doable. Specs are below.
OS device name: E:
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: **********
Firmware date: 2014-12-26
Highest AACS version: 68
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
OS device name: E:
Revision: 3.01
sure email me that info see belowbovidvkbs88 wrote: ↑Fri Jul 04, 2025 2:51 pmHello all. I have a old PIONEER and I wanted to see if anyone can help me confirm if the FW Flash is doable. Specs are below.
OS device name: E:
Revision: 3.01
Got me an ASUS BW-16D1X-U
OS device name: \Device\CdRom2
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 78
Firmware version: ID76
I presume since I've seen flashes for the E116 version, that the E113 also has a patcher?
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Hi - I have the following drive, how can I get this working?
OS device name: /dev/sr0
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number: DHDL012265UC
Firmware date: 2022-12-27
Drive platform: Pioneer RS9330
Firmware version: GENE
Revision: 1.02
Nope. The firmware is too new so your drive cannot be flashed to enable libredrive and UHD support. You will have to wait for future support.cms168 wrote: ↑Sat Jul 05, 2025 3:27 amHi - I have the following drive, how can I get this working?
Revision: 1.02
InnocentBlood
Hello I would like some advice on where I can download the firmware for my BDR-XD05 drive please, thank you.
Revision: 3.01
Serial number: redacted
Highest AACS version: 81
Revision: 3.01
yes can do UHD email me for the flasherInnocentBlood wrote: ↑Wed Jul 09, 2025 7:18 amHello I would like some advice on where I can download the firmware for my BDR-XD05 drive please, thank you.
Revision: 3.01
Greetings. I'm VERY new to this. I'm looking to buy a blu ray drive to rip discs, including 4k UHD discs.
1. What are the best drives to purchase (makes and models)?
2. Which have the least difficulty accepting libredive firmware (makes and models)?
3. Price is an issue, but right no I'm just interested in knowing what works best and easiest.
I appreciate any help! Don't want to waste my time and money.
I have an M2 Mac running sequoia 15.5. I can also run a windows VM, if that makes a difference.
Thanks!!!
Thanks!!!
Tell us your country of residence.josmbrake wrote: ↑Thu Jul 10, 2025 4:37 pmGreetings. I'm VERY new to this. I'm looking to buy a blu ray drive to rip discs, including 4k UHD discs.
Thanks!!!
