Asus BW-16D1X-U
MysticWizard
Re: Asus BW-16D1X-U
Post by MysticWizard » Wed May 14, 2025 5:52 pm
Coopervid wrote: Tue May 13, 2025 3:02 am
MysticWizard wrote: Sat May 10, 2025 2:12 pm Back when I bought my external drive, I was dissapointed to find out it was not UHD friendly, some even claimed it could not read UHD bc hardware was not present. Decided today to see if anything changed and am unsure if it has. Here's my drive info, still no UHD?
Also if it is possible, will I lose the capability to write 100GB M-Disks?
Thanks for your time!
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number:
Firmware date: 2019-03-07
Drive platform: RS8F00
Firmware version: E115/ID71
PM sent. You will just add capabilities.
Emphasis8365
Re: Asus BW-16D1X-U
Post by Emphasis8365 » Mon May 19, 2025 12:41 pm
I was hoping I could get some help with my new optical drive. When inserting a DVD I can play it on my laptop running Linux Mint, but MakeMKV is simply stuck "Loading...". Looking at the debug logs it says "No SDF v098: ASUS_BW-16D1H-U_A205_212012011818_[serial]", so I figured I probably have to flash the drive. I have tried running sdftool dump, sdftool flash and flashing using makemkvcon, but it every time the process is stuck with 100% CPU usage and no output in the terminal. Any ideas?
[Edit]: Downgraded to MakeMKV 1.17.6 and was able to successfully flash.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: A205
Serial number: [serial]
Firmware date: 2120-12-01 18:18
Bus encryption flags: 1F
peerzet1897
Re: Asus BW-16D1X-U
Post by peerzet1897 » Fri Jun 20, 2025 11:42 am
Coopervid wrote: Sun May 04, 2025 8:47 pm
leifeng wrote: Sun May 04, 2025 9:54 am hello guys,I need some help to flash my drive
PM sent.
Hello, I have a similar situation, I would like to be able to rip UHD discs in my ASUS BW-16D1H-U Pro. This is the output from MakeMKV app:
OS device name: J:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 81
Firmware version: E116/ID71
I wanted to sent PM directly to Coopervid since I've been informed that this it the person I should ask for help, but unfortunately I don't have possibility to send PM to anyone.
I would be grateful if you could help me with flashing my drive!
Also - one more question: do the firmware update changes something when it comes to burning Blu-ray discs? I remember that it was an issue (probably for LG drives?) that after an update burning would be impossible. How does it look like with my drive?
Re: Asus BW-16D1X-U
Post by Coopervid » Fri Jun 20, 2025 1:24 pm
peerzet1897 wrote: Fri Jun 20, 2025 11:42 am
PM sent.
OS device name: J:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E116
Serial number:
PM sent. No. The firmware doesn't affect burning.
DMZSniper
Re: Asus BW-16D1X-U
Post by DMZSniper » Fri Jul 04, 2025 11:35 pm
Hey Cooper,
Is there still a flash for the E113 version?
OS device name: \Device\CdRom2
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
Highest AACS version: 78
Firmware version: ID76
Re: Asus BW-16D1X-U
Post by Coopervid » Sat Jul 05, 2025 8:22 pm
DMZSniper wrote: Fri Jul 04, 2025 11:35 pm Hey Cooper,
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
DMZSniper
Re: Asus BW-16D1X-U
Post by DMZSniper » Sat Jul 05, 2025 9:23 pm
Coopervid wrote: Sat Jul 05, 2025 8:22 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Hey Cooper, much love, seems to have worked, but I'm seeing _lower_ write speeds on the drive now (used to average 6x-9x and s now staying around 3,9x. The drive also isn't reporting as a UHD capable drive in the program, all of the UHD options remain unticked.
Re: Asus BW-16D1X-U
Post by Coopervid » Sat Jul 05, 2025 9:51 pm
DMZSniper wrote: Sat Jul 05, 2025 9:23 pm
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E113
Serial number:
PM sent.
Post Makemkv info with an UHD in the drive. Pioneer UHD ripping is 4x max. That's normal.
Re: Asus BW-16D1X-U
Post by Coopervid » Sat Jul 05, 2025 9:52 pm
Coopervid wrote: Sat Jul 05, 2025 9:51 pm
PM sent.
Post Makemkv info with an UHD in the drive. Pioneer UHD ripping is 4x max. That's normal. DID YOU REBOOT?
DMZSniper
Re: Asus BW-16D1X-U
Post by DMZSniper » Sat Jul 05, 2025 10:12 pm
As per instructions, I completely disconnected and powered off the drive itself, PC stayed on.
I notice that ripping non-UHD discs in MakeMKV now constantly fails on some of the files. This did not happen before whatsoever.
DMZSniper
Re: Asus BW-16D1X-U
Post by DMZSniper » Sun Jul 06, 2025 1:11 am
Rebooting does not fix the issue, and drive is indeed having serious issues after flashing with the exact instructions. It's failing to copy any disc, showing as ' disconnected' multiple times, which makes MakeMKV skip files. I don't currently have UHD discs needing ripping, so I'm using regular disks.
OS device name: K:
Manufacturer: PIONEER
Product: BD-RW BDR-S12U
Revision: 1.02
Serial number:
Firmware date: 2022-03-07
Drive platform: RS8F01
Firmware version: 1.02/ID43
LibreDrive is enabled, but it isn't working correctly it seems.
Re: Asus BW-16D1X-U
Post by Coopervid » Sun Jul 06, 2025 12:05 pm
Such a thing has never been reported before. Is this a drive in an USB enclosure? If yes you need to remove power AND USB. Otherwise the drive electronics is still powered by the USB connection.
These errors can also originate if the drive doesn't get enough power. Maybe with the new firmware it needs more power.
DMZSniper
Re: Asus BW-16D1X-U
Post by DMZSniper » Sun Jul 06, 2025 3:04 pm
Coopervid wrote: Sun Jul 06, 2025 12:05 pm Such a thing has never been reported before. Is this a drive in an USB enclosure? If yes you need to remove power AND USB. Otherwise the drive electronics is still powered by the USB connection.
Oh I'm assuming it's a skill issue on my end. I powered it down and removed USB as stated in the guide.
Maybe it's just a different enough platform that it doesn't work that well. I've also looked at BDRFlash options and tried a few after I first saw the issue. Reducing peak power mode doesn't seem to help much, so I doubt it's a power issue.
It's inconsistent on different discs and fails different files even in multiple runs of the same disc.
I suppose for all successful flashes someone has to fail. No hard feelings, I'll reflash this to original firmware.
Re: Asus BW-16D1X-U
Post by Coopervid » Sun Jul 06, 2025 3:21 pm
You can try to flash it once more. If it doesn't help, please post the errors in Makemkv you get.
HSamwel
Re: Asus BW-16D1X-U
Post by HSamwel » Sun Jul 13, 2025 11:34 am
DMZSniper wrote: Sun Jul 06, 2025 3:04 pm
I have the exact same model, with the USB 3 ASUS enclosure. Worked perfectly.
I did a complete shutdown, including my laptop, and then a restart.
I have currently ripped 13 of my UHD discs and no errors or anything.
What’s you computer setup?
I have a ASUS laptop with Core i5, 32GB mem, Win11, USB3.2 connection.
