After updating to v1.7 i get the warning seen on the attached screenshot. I have never had AnyDVD installed. I searched the registry for "AnyDVD", no hits.
Any suggestions?
UncleSam
Strange message in v1.7
- AnyDVD.png (7.75 KiB) Viewed 11719 times
Re: Strange message in v1.7
You're using MakeMKV on content that was previously ripped using AnyDVD.
You are probably right, thanks.
UncleSam
UncleSam
I've never installed AnyDVD & had the same message, so downloaded image must of been created with AnyDVD.
I dont get why the MakeMKV popup tells the user to disable AnyDVD when it was never enabled/installed in the first place, this popup IMO needs editing
Smithcraft
There is not much support for downloaded images here.
SC
SC
Smithcraft wrote:There is not much support for downloaded images here.
SC
Ohh I didnt realise a family wedding DVD image was off topic
setarip_old
@netwave
Hi!
A simple request/suggestion - Avoiding references to other than purchased media is appreciated at this forum ;>}
Hi!
It's not - nor is a wedding DVD image typically prepared with the use of AnyDVD.Ohh I didnt realise a family wedding DVD image was off topic
