Ultimate UHD Drives Flashing Guide Updated 2025
savagedane
I figured I'd give this a go and ask - can this drive be flashed to read UHDs?
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-S09
Revision: 1.54
Serial number: XXXXXXXXXXXX
Firmware date: 2020-07-21
Highest AACS version: 81
Drive platform: RS8600
Firmware version: 1.54/ID43
OS device name: G:
Revision: 1.54
Yes email me that info see below I can send you the flashersavagedane wrote: ↑Sun Jun 29, 2025 9:02 amI figured I'd give this a go and ask - can this drive be flashed to read UHDs?
OS device name: G:
Revision: 1.54
No. You will have to wait until newer drives are supported. Could be quite a while...jrips wrote: ↑Sun Jun 29, 2025 4:10 amHi guys,
I bought a Pioneer BDR-XS07TUHD risking that it would be revision 1.03 which it is. Is it possible to get into a libredrive mode or not?Code: Select all
Product: BD-RW BDR Revision: 1.03 Firmware date 2023-01-06 Drive platform: Pioneer RS8E21 Firmware version: ID05
Rodger_dodger54
To Billy et al.
I inherited my brother’s 500 disk 4K blu-ray collection (and only 4K) but I am a digital guy with NAS. Enter MakeMKV and a drive. Been reading many posts on this forum. I have studied this post and others. It appears Pioneer is the most reliable/best/recommended drive.
From what I read, they were not flashable, but now they are, but now they will no longer be sold or are near the end. Your PSA “PSA now most Pioneers come with new fw that prevents them from be crossflashed or downgraded do not buy one for UHD at this time” has me a little confused what to go after — do I try and find a pioneer? Do I avoid and go after Asus or LG? I read the LibreDrive discussion and saw Asus and LG are compatible. Is that better to be Libre and non-Pioneer or buy the pioneer and wait?
I found the Pioneer drive (Pioneer BDR-XD08UMB-S) in stock on Amazon and it appears from the updated flashing guide that it will work. I’m comfortable in command line but don’t want to make rookie mistakes, hence my inquiry. I saw you have some for sale but I’m on a newer (usb-c) mac and want something lightweight that does not require me to get an additional computer for windows. Otherwise, I’d just buy one of your pre-flashed drives and be done with it. Is the drive I mention appropriate/supported? Is this something that would theoretically be libre compatible in the future? Is there an auto-flash option for the drive I mentioned that I can pay (Billy) for to take the guess work out?
Many thanks for your good work.
It will have firmware that is too new and cannot be flashed. Really, the only Pioneer you can get from a store that can be flashed is the BDR-212V. If you want any other model, the only place to get a UHD comaptibel one is from a seller on these forums.Rodger_dodger54 wrote: ↑Tue Jul 01, 2025 2:41 amTo Billy et al.
Just to clarify, the BDR-212V can be flashed by the end user, i.e. me?MartyMcNuts wrote: ↑Wed Jul 02, 2025 2:16 amIt will have firmware that is too new and cannot be flashed. Really, the only Pioneer you can get from a store that can be flashed is the BDR-212V. If you want any other model, the only place to get a UHD comaptibel one is from a seller on these forums.Rodger_dodger54 wrote: ↑Tue Jul 01, 2025 2:41 amTo Billy et al.
The flasher for Pioneer is not public. You should contact Billycar11 for assistance once you have the drive.Mr_Orange wrote: ↑Wed Jul 02, 2025 2:39 amJust to clarify, the BDR-212V can be flashed by the end user, i.e. me?MartyMcNuts wrote: ↑Wed Jul 02, 2025 2:16 amIt will have firmware that is too new and cannot be flashed. Really, the only Pioneer you can get from a store that can be flashed is the BDR-212V. If you want any other model, the only place to get a UHD comaptibel one is from a seller on these forums.Rodger_dodger54 wrote: ↑Tue Jul 01, 2025 2:41 amTo Billy et al.
Got a new BP50NB40 to test out (as I'm having trouble with another internal drive). Followed the firmware update instructions, writing the BP50NB40-NB50-1.03MK and then using recover to change it to BP60NB10 1.00MK. It's reading a disc now without trouble but it's topping out at 4.1X in the read rate. That normal for a triple layer disc? Also, any advantage to upgrading to 1.02MK?
No advantage with 1.02-MK.chronomac wrote: ↑Wed Jul 02, 2025 8:11 pmGot a new BP50NB40 to test out (as I'm having trouble with another internal drive). Followed the firmware update instructions, writing the BP50NB40-NB50-1.03MK and then using recover to change it to BP60NB10 1.00MK. It's reading a disc now without trouble but it's topping out at 4.1X in the read rate. That normal for a triple layer disc? Also, any advantage to upgrading to 1.02MK?
Yeah, 4.1x is ok. Disc maybe a little hard to read. Usually read between 4.0 and the 6.0x max, which it might get to at some point in the rip.
Hello, please forgive my ignorance. I have attempted to flash my WH16NS40 drive and want to know if it was successful.
./makemkvcon f -d '/IOBDServices/2A065125' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Reading input file /tmp/HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_M00M2GL3716
yes
100% Operation finished
Done successfully
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: M00M2GL3716
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.05
yes
Done successfully
Revision: 1.05
Try
./makemkvcon f -d '/IOBDServices/2A065125' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Hi
I'd like to make the following drive UHD capable by crossflashing it to BDR-S11. Who can help me? Thank you
OS device name: G:
Product: BD-RW BDR-209M
Revision: 8.11
Serial number: NLDLXXXXXXXX
Firmware date: 2014-01-16
Highest AACS version: 76
Firmware version: 8.11/ID52
OS device name: G:
Revision: 8.11
Sure email me that drive info see belowblackice wrote: ↑Thu Jul 03, 2025 1:03 pmHi
OS device name: G:
Revision: 8.11
Rodger_dodger54
Will your Verbatim 43888 work with MacOS 15?MartyMcNuts wrote: ↑Wed Jul 02, 2025 2:16 amIt will have firmware that is too new and cannot be flashed. Really, the only Pioneer you can get from a store that can be flashed is the BDR-212V. If you want any other model, the only place to get a UHD comaptibel one is from a seller on these forums.Rodger_dodger54 wrote: ↑Tue Jul 01, 2025 2:41 amTo Billy et al.
Yes but just know it will likely need to be flashed as all the pioneer ones are gone
