Colombiana Error
ABO2012
Colombiana Error
Post by ABO2012 »
Got the following error while converting Colombiana:
MakeMKV v1.7.0 darwin(x86-release) started
Optical drive "BD-ROM ASUS SBC-06D1S-U A301" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
This disc uses newer version of AACS protection. Please let us know about it by visiting http://www.makemkv.com/a/?4kgaOC66LsCCRp...
File 00099.mpls was added as title #0
File 00001.mpls was added as title #1
File 00102.mpls was added as title #2
Title #00999.mpls has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00095.mpls is equal to title 00099.mpls and was skipped
Title 00096.mpls is equal to title 00099.mpls and was skipped
Title #00100.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00502.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00503.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00504.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #04999.m2ts has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.m2ts has length of 3 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.m2ts has length of 42 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00015.m2ts was added as title #3
File 00016.m2ts was added as title #4
File 00017.m2ts was added as title #5
File 00018.m2ts was added as title #6
File 00019.m2ts was added as title #7
File 00020.m2ts was added as title #8
File 00021.m2ts was added as title #9
File 00022.m2ts was added as title #10
File 00023.m2ts was added as title #11
File 00024.m2ts was added as title #12
File 00025.m2ts was added as title #13
Saving 1 titles into directory /Users/victorilog/Desktop/Unformatted Movies
Error 'Posix error - Input/output error' occurred while reading '/BDMV/STREAM/00001.m2ts' at offset '19831062528'
Failed to save title 1 to file /Users/victorilog/Desktop/Unformatted Movies/t01_Colombiana.mkv
0 titles saved, 1 failed
Any fixes?
crowfax
Re: Colombiana Error
Post by crowfax »
Do this. Try again.
Explanation:
http://www.makemkv.com/forum2/viewtopic.php?f=4&t=2564
