Dumb submitted - CHUNGKING EXPRESS UHD
jenrashe
Post by jenrashe »
emailed MKB20_v77_CHUNGKING_EXPRESS_1164.tgz
https://drive.google.com/file/d/1jNC1bY ... drive_link
keydb_helper
Re: Dumb submitted - CHUNGKING EXPRESS UHD
Post by keydb_helper »
jenrashe wrote:
Wed Jul 02, 2025 2:17 pm
Thanks for providing a suitable disc dump file. The 1164 variant of Chungking Express has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
  • LG/Buffalo/Asus drives only (Pioneer drives are not supported)
  • If your disc dump is under 3MB, you need to manually include the MKB_RO.inf file from the AACS folder
jenrashe
Post by jenrashe »
Getting disc info...
Validation Data: E3DBBE23A302B28BD0B0A7B6DD8FC269 [FOUND]
Media Key: C97C8F69C57A5B405ECA6818BBD9F72A [VALID]
VUK: 65CF2F9CEA2AB8E6CB6A1BBBE5FB46BC [VALID]
Encrypted Unit Key: 6339BB15E187740E8E934E334B9F7885 [FOUND]
Decrypted Unit Key: BB7B37166AA18055059A3478B0488023 [FOUND]
Unit Key(s) tested with 3 aligned units : [VALIDATED]
[(Disc Info)]
[DiscID]: 0x67225E52A5CEF7F635D0822C6CD7E80C806DF9FB
[Volume]: CHUNGKING EXPRESS
[Title]: Chungking Express
[Date]: 2025-01-18
[MediaKey]: 0xC97C8F69C57A5B405ECA6818BBD9F72A
[VID]: 0xCF9E898F7FAFCFA0C0813EEE8CCFF330
[VUK]: 0x65CF2F9CEA2AB8E6CB6A1BBBE5FB46BC
[MKB]: 77
[UnitKey]: 1-0xBB7B37166AA18055059A3478B0488023
[KEYDB_STATUS]: (NOTVALIDATED)
[STATUS]: complete
[DiscType]: UHD
Starting FindVUK validate disc!
Validation complete!
it s working for this thanks
