Any workaround for discs not recognized after firmware downgrade?
Wherch
Post by Wherch » Wed Jul 02, 2025 7:11 am
I recently downgraded my LG WH16NS40 to 1.02 to enable LibreDrive, following the instructions from the forums. Flash went fine and MakeMKV shows LibreDrive enabled.
However, now some of my UHD discs aren’t recognized at all. The drive spins but doesn’t load MakeMKV just says No disc inserted. These same discs worked before the downgrade.
Is there something I missed?
Do I need to use a different SDF tool version?
Should I try 1.03-MK firmware instead?
Re: Any workaround for discs not recognized after firmware downgrade?
Post by MartyMcNuts » Wed Jul 02, 2025 11:51 pm
Wherch wrote: Wed Jul 02, 2025 7:11 am I recently downgraded my LG WH16NS40 to 1.02 to enable LibreDrive, following the instructions from the forums. Flash went fine and MakeMKV shows LibreDrive enabled.
WH16NS60 1.02-MK is the recommended firmware.
Let the OS initialize the disc before opening MakeMKV. Clean the disc if it has trouble reading it.
