Sudden video corruption
Archbishopfocwod
Post by Archbishopfocwod »
I've noticed a recurring issue with video corruption in the last dozen or so movies I've ripped. The corruption appears periodically and is repeatable at the same timestamp.
To troubleshoot, I've tried ripping to different hard drives, but the issue persists, though at different points in the movie. Additionally, I re-ripped a movie that I had successfully ripped years ago, and it now also exhibits the same corruption issues that were not present in the original rip.
Given that I've ruled out multiple hard drives and multiple movies, and the issue remains with the Blu-ray drive as the only constant variable, would it be accurate to assume that my Blu-ray drive is failing?
Re: Sudden video corruption
Could be bad ram too seen that before but that would be more random
Archbishopfocwod
It almost seems as if the corruption is baked into the video file because it always happens at the same spots. I would think bad RAM would be random.
wait a min are you using windows media player or whatever they call it now to play it?
i thought you were getting errors ripping if you not its player you are using to play it use vlc jriver or many others not built in windows junk
