Did I purchase a fake pioneer drive BDR-209
DC-2187
Post by DC-2187 » Tue Jul 01, 2025 1:11 am
Hello everyone,
I was wondering if I perhaps purchased a fake pioneer drive. The drive just looks different compared to the other pioneer drives I purchased before. I got it on ebay and the seller had good feedback. Maybe I'm just wrong but I would like some thoughts from the community. I will attach some pictures and a screenshot. My biggest question is the drive was made in 2022 but has firmware from 2014? Is that possible? I would think it would be much newer. Also the sticker on the drive looks much different to others. I just want to make sure it's legit drive.
Thanks.
Re: Did I purchase a fake pioneer drive BDR-209
Post by Coopervid » Tue Jul 01, 2025 10:16 am
My theory is that this is a return.
Somebody has a drive that causes trouble somehow, e.g. polluted laser lens. He orders a new one and exchanges the housing parts between his old one and the new one. Then he sends his old drive back and asks for a refund. This way he has a new drive at no cost.
I have never come across a fake Pioneer drive. So this is one is a Pioneer drive but I suspect you will not be happy with it according to my theory above.
Post by Billycar11 » Tue Jul 01, 2025 10:40 am
idk there is something funny
all pioneers i have seen sn matches fw sn most end in WL not numbers
the top stamping pattern looks different from other pioneer 208/9's i have
Batman&throbbin
Post by Batman&throbbin » Tue Jul 01, 2025 11:33 am
They are different internally.
The press/fabrication is more similar to Sony Optiarc as an attempt to copy…
Pioneer would never apply a label partially like that…
Better off buying a genuine used Pioneer on eBay, there are many of what you purchased as new on Amazon too…
It needs cleaning up really…
Counterfeiting is still rife so don’t entertain it.
DC-2187
Post by DC-2187 » Tue Jul 01, 2025 2:13 pm
Billycar11 wrote: Tue Jul 01, 2025 10:40 am idk there is something funny
This is exactly why I'm asking. I saw other listings when I went back to look yesterday that had the same serial number. Also as you stated I have other another pioneer 209 drive and it looks completely different. I'm probably just going to return it
Post by Billycar11 » Tue Jul 01, 2025 6:13 pm
DC-2187 wrote: Tue Jul 01, 2025 2:13 pm
Honestly it's probably still better than an LG
Flash it and see if does UHD email me for that
It seems to be a pioneer clone.
Post by Coopervid » Tue Jul 01, 2025 6:21 pm
That sounds interesting. A "Pioneer clone". Let's see how it performs regarding reading. If DC-2187 has a full size LG drive we could also do burn tests afterwards and check the burn quality.
DC-2187
Post by DC-2187 » Tue Jul 01, 2025 9:26 pm
I actually do have a LG full size drive. Its my first drive I ever got years ago and even flashed it. Haven't used it much since I started using pioneer drives. It still rips DVD/blu-ray fine enough but it doesn't do UHD discs. I should maybe do some tests on it.
Post by Coopervid » Tue Jul 01, 2025 9:35 pm
DC-2187 wrote: Tue Jul 01, 2025 9:26 pm I actually do have a LG full size drive. Its my first drive I ever got years ago and even flashed it. Haven't used it much since I started using pioneer drives. It still rips DVD/blu-ray fine enough but it doesn't do UHD discs. I should maybe do some tests on it.
I'll sent yo the package to do quality tests with VPTools. And the firmware to flash this drive to a S11. Then rip discs. If OK burn discs and scan them with the LG flashed to WH16NS58 1.V5.
Post by Coopervid » Tue Jul 01, 2025 9:58 pm
So you have:
Tool to flash to S11 for UHD
Firmware 1.V5 for WH16NS58 wich allows to do burn quality checks.
VPTools to do so
You decide if you want to proceed.
DC-2187
Post by DC-2187 » Tue Jul 01, 2025 10:01 pm
Coopervid wrote: Tue Jul 01, 2025 9:58 pm So you have:
VPTools to do so
Yeah I'm down to do this. Should be interesting.
Update: I got both drives flashed now and just need to pick up some blank blu-ray discs to burn with. I do have some blank DVDs so I can get started with that tomorrow night. I forgot to ask what discs are best to test with 25, 50 or 100 gb?
Post by Coopervid » Wed Jul 02, 2025 9:39 am
I have sent a PM with that link:
https://forum.doom9.org/showthread.php?t=185539&page=19
So you can burn discs with this drive, your other Pioneer and also the WH16NS58 which is mainly supposed to do the scans.
25 GB is a good start, 50GB is challenging since the media quality has worsened dramatically but it will most likely give the best comparative results. 100 GB media is similar and because of the high costs of these discs not necessary in my opinion.
If the drive performs really bad I can also send 209DBK firmware so you can flash it back before returning it.
DC-2187
Post by DC-2187 » Sun Jul 06, 2025 10:43 pm
Finally was able to do some produce some discs and have them tested thanks to Coopervid for the assistance.
I"m not too familiar with reading the results. I would say from what I have been told the best results come from the pioneer burned discs. I hope I did everything correctly in burning the discs. Also to add I just picked up the Verbatim 25 gb BD-R disc to test. I didn't do any research on this so I'm not sure if I could of picked up a better disc to test with.
Edit: the screenshots didn't upload. I'm have to link to them. https://imgur.com/a/C9zW4TU
Post by Coopervid » Mon Jul 07, 2025 9:32 am
All your results are very good. The higher values at the end are caused by the discs and not by the burners. So this "clone drive" behaves exactly as an original Pioneer drive. They might use Pioneer components and just use different housings.
It's up to you if you want to keep it and I'm wondering if we will see more of those in the near future now Pioneer is out of the game.
DC-2187
Post by DC-2187 » Mon Jul 07, 2025 7:04 pm
Oh interesting. This is good to know. I probably will just keep it. I didn't spend alot on it so it it behaves and works like a pioneer drive then it's a plus I guess.
Should be interesting how the drive business goes from here now that pioneer is out of the game. At least for now I got a good number of drives so I won't have to worry about buying any second hand drives.
