BU40N poor performance
Bolek
Post by Bolek »
Is it just my drive that behaves like a piece of junk? It's loud, but that can be forgiven in the end, but the worst thing is the loud head moving every 20 seconds when playing movies from discs. Is my burner faulty or is it just a feature of it?
MartyMcNuts wrote: Mon Jun 16, 2025 12:03 am The BU40N is better than any LG/ASUS internal 5.25" drive.
When I read such opinions, I laugh out loud, because I also have the LG WH16NS40 and this drive performs several classes better.
zittrig
Re: BU40N poor performance
Post by zittrig »
Even a good drive could become defective.
But first I would clean the lenses before throwing in the trash can.
Bolek wrote: Tue Jul 01, 2025 1:15 pm Is it just my drive that behaves like a piece of junk? It's loud, but that can be forgiven in the end, but the worst thing is the loud head moving every 20 seconds when playing movies from discs. Is my burner faulty or is it just a feature of it?
You must have been one of the lucky one's! I've had hundreds of the LG internal drives and 9/10 were junk units that had to be returned. LG's QC went to sh!t around 2020. Drives before that were good. It was rare to get a bad one but since then has been the opposite.
blind-s33r
Post by blind-s33r »
I've been using a bu40n in a vantec enclosure for years now... its loud and likes to move around alot but anytime it starts to have trouble reading discs I just clean the lens off with a microfibre cloth and its back to running great... the lens on this thing loves to pick up dust I guess but as its lens is easily accessible it makes it easy to fix imho.
Cid67
Post by Cid67 »
earlier variants where less reliable. stay clear of models from around 2016 and stick with 2023 models if possible.
