#3016 Post by MartyMcNuts » Mon Jun 30, 2025 12:55 am
jrips wrote: Sun Jun 29, 2025 4:10 am Hi guys,
I bought a Pioneer BDR-XS07TUHD risking that it would be revision 1.03 which it is. Is it possible to get into a libredrive mode or not?
Product: BD-RW BDR
Revision: 1.03
Firmware date 2023-01-06
Firmware version: ID05
No. You will have to wait until newer drives are supported. Could be quite a while...
Rodger_dodger54
#3017 Post by Rodger_dodger54 » Tue Jul 01, 2025 2:41 am
To Billy et al.
I inherited my brother’s 500 disk 4K blu-ray collection (and only 4K) but I am a digital guy with NAS. Enter MakeMKV and a drive. Been reading many posts on this forum. I have studied this post and others. It appears Pioneer is the most reliable/best/recommended drive.
From what I read, they were not flashable, but now they are, but now they will no longer be sold or are near the end. Your PSA “PSA now most Pioneers come with new fw that prevents them from be crossflashed or downgraded do not buy one for UHD at this time” has me a little confused what to go after — do I try and find a pioneer? Do I avoid and go after Asus or LG? I read the LibreDrive discussion and saw Asus and LG are compatible. Is that better to be Libre and non-Pioneer or buy the pioneer and wait?
I found the Pioneer drive (Pioneer BDR-XD08UMB-S) in stock on Amazon and it appears from the updated flashing guide that it will work. I’m comfortable in command line but don’t want to make rookie mistakes, hence my inquiry. I saw you have some for sale but I’m on a newer (usb-c) mac and want something lightweight that does not require me to get an additional computer for windows. Otherwise, I’d just buy one of your pre-flashed drives and be done with it. Is the drive I mention appropriate/supported? Is this something that would theoretically be libre compatible in the future? Is there an auto-flash option for the drive I mentioned that I can pay (Billy) for to take the guess work out?
Many thanks for your good work.
#3018 Post by MartyMcNuts » Wed Jul 02, 2025 2:16 am
Rodger_dodger54 wrote: Tue Jul 01, 2025 2:41 am To Billy et al.
It will have firmware that is too new and cannot be flashed. Really, the only Pioneer you can get from a store that can be flashed is the BDR-212V. If you want any other model, the only place to get a UHD comaptibel one is from a seller on these forums.
Mr_Orange
#3019 Post by Mr_Orange » Wed Jul 02, 2025 2:39 am
MartyMcNuts wrote: Wed Jul 02, 2025 2:16 am
Just to clarify, the BDR-212V can be flashed by the end user, i.e. me?
#3020 Post by MartyMcNuts » Wed Jul 02, 2025 3:06 am
Mr_Orange wrote: Wed Jul 02, 2025 2:39 am
The flasher for Pioneer is not public. You should contact Billycar11 for assistance once you have the drive.
chronomac
#3021 Post by chronomac » Wed Jul 02, 2025 8:11 pm
Got a new BP50NB40 to test out (as I'm having trouble with another internal drive). Followed the firmware update instructions, writing the BP50NB40-NB50-1.03MK and then using recover to change it to BP60NB10 1.00MK. It's reading a disc now without trouble but it's topping out at 4.1X in the read rate. That normal for a triple layer disc? Also, any advantage to upgrading to 1.02MK?
#3022 Post by MartyMcNuts » Wed Jul 02, 2025 11:44 pm
chronomac wrote: Wed Jul 02, 2025 8:11 pm Got a new BP50NB40 to test out (as I'm having trouble with another internal drive). Followed the firmware update instructions, writing the BP50NB40-NB50-1.03MK and then using recover to change it to BP60NB10 1.00MK. It's reading a disc now without trouble but it's topping out at 4.1X in the read rate. That normal for a triple layer disc? Also, any advantage to upgrading to 1.02MK?
No advantage with 1.02-MK.
Yeah, 4.1x is ok. Disc maybe a little hard to read. Usually read between 4.0 and the 6.0x max, which it might get to at some point in the rip.
YPBPr
#3023 Post by YPBPr » Thu Jul 03, 2025 6:30 am
Hello, please forgive my ignorance. I have attempted to flash my WH16NS40 drive and want to know if it was successful.
./makemkvcon f -d '/IOBDServices/2A065125' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Reading input file /tmp/HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
Current Drive ID: HL-DT-ST_BD-RE__WH16NS40_1.05_212005061440_M00M2GL3716
yes
100% Operation finished
Done successfully
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: M00M2GL3716
Highest AACS version: 61
Harware support: Yes
Firmware support: No
Firmware version: 1.05
#3024 Post by d00zah » Thu Jul 03, 2025 12:49 pm
Try
./makemkvcon f -d '/IOBDServices/2A065125' -f /tmp/sdf.bin rawflash enc -i /tmp/HL-DT-ST-BD-RE_WH16NS40-NS50-1.05-NM00900-212005061440.bin
blackice
#3025 Post by blackice » Thu Jul 03, 2025 1:03 pm
Hi
I'd like to make the following drive UHD capable by crossflashing it to BDR-S11. Who can help me? Thank you :-)
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 8.11
Serial number: NLDLXXXXXXXX
Firmware date: 2014-01-16
Highest AACS version: 76
Drive platform: RS8600
Firmware version: 8.11/ID52
#3026 Post by Billycar11 » Thu Jul 03, 2025 2:47 pm
blackice wrote: Thu Jul 03, 2025 1:03 pm Hi
OS device name: G:
Revision: 8.11
Sure email me that drive info see below
Rodger_dodger54
#3027 Post by Rodger_dodger54 » Thu Jul 03, 2025 4:37 pm
Will your Verbatim 43888 work with MacOS 15?
#3028 Post by Billycar11 » Thu Jul 03, 2025 7:05 pm
Rodger_dodger54 wrote: Thu Jul 03, 2025 4:37 pm Will your Verbatim 43888 work with MacOS 15?
Yes but just know it will likely need to be flashed as all the pioneer ones are gone
Rodger_dodger54
#3029 Post by Rodger_dodger54 » Thu Jul 03, 2025 7:39 pm
Billycar11 wrote: Thu Jul 03, 2025 7:05 pm
Got it. I do not know the history of this firmware arms race. will there ever be a time in the future when you can buy an off the shelf uhd capable drive that will work without flashing?
Rodger_dodger54
#3030 Post by Rodger_dodger54 » Thu Jul 03, 2025 8:20 pm
The pioneer ones, such as the ones from asmcom, don't need flashing, correct?
