BDR-S12XJ Need Flash for UHD?
Alex77
Post by Alex77 » Mon Jun 30, 2025 4:01 pm
I purchased a BDR-S12XJ and was wondering if it will need a flash to read UHD blurays even if it has a firmware before December 2022? It is advertised as capable of "4K Ultra HD Blu-ray playback" so i was thinking a flash wouldn't be necessary. Any help would be appreciated.
Here is the link to the one I bought:
https://www.amazon.com/Internal-Blu-ray ... C96&sr=1-7
Re: BDR-S12XJ Need Flash for UHD?
Post by Coopervid » Mon Jun 30, 2025 4:55 pm
Put an UHD disc in it and try. It‘s as easy as that.
Alex77
Post by Alex77 » Mon Jun 30, 2025 5:23 pm
I'm still waiting on it to be delivered, I just was wondering if anyone knew if it would work with UHD disc without a flash. I'll test it out tomorrow and give an update.
Post by Coopervid » Tue Jul 01, 2025 11:53 am
It should be the Japanese version of the S12UHT. Can you please post your Makemkv info. Hopefully it has firmware before Dec. 2022. Then it could be flashed for UHD and it should then be Libredrive compatible.
Alex77
Post by Alex77 » Tue Jul 01, 2025 8:40 pm
I received it and the firmware is from 2020, looks like the equivalent to the BDR-S12XJ is the BDR-212UBK. I put a 4k Blu-ray in it and it ripped fine. I didn't flash it or anything like that. Works perfectly straight out of the box.
Post by Coopervid » Wed Jul 02, 2025 9:58 am
Good to hear that it works and that it has old firmware! The S12XJ is the same a S12UHT (comes with software). The version without software is the 212UBK but all 3 have the same technical specs.
