Pioneer BDR-208 (rebadged as ASUS BW-12D1S-U) manufactured in 2013, possible to do UHD?
opticalhoarder
Post by opticalhoarder »
As per the subject, I've got ASUS BW-12D1S-U drive that is a rebadged Pioneer BDR-208. Manufacture date is mid 2013.
Can this ancient drive be flashed to do UHD?
Info from MKV:
OS device name: K:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
Serial number: xxxxxxxxxxxx
Firmware date: 2013-02-25
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: E301/ID71
Also, this drive brings back some memories. Back when the MyCE forums were still up (I think in 2021, based on the dates on some files), I was contacted by Blackened2687 about dumping this drive. This drive was subsequently dumped with Blackened2687's "Pioneer Data Dumper" tool, and I sent the firmware back in. Maybe this drive even contributed to some of the efforts in unlocking Pioneer drives!
Re: Pioneer BDR-208 (rebadged as ASUS BW-12D1S-U) manufactured in 2013, possible to do UHD?
Sure email me that drive info and I can send you a flasher see below
opticalhoarder
Billycar11 wrote: Sun Jun 29, 2025 2:41 pm Sure email me that drive info and I can send you a flasher see below
Sounds good. Email sent, subject "RE: Pioneer BDR-208 (rebadged as ASUS BW-12D1S-U) manufactured in 2013, possible to do UHD?"
K92311b2p
Post by K92311b2p »
I also have this drive and am looking to flash if possible . Any help would be greatly appreciated.I am not sure I am requesting this correctly if not please advise.
Drive information
Manufacturer:Asus
Product: BW-12D1S-u
Revision:E402
Firmware date 2018-01-15
Bus encryption flags:1B
Highest AACS version 75
Liber drive information
Status enabled
Drive platform :Rs8600
Firmware Name Pioneer BDR-209
Firmware type:Original (unpatched)
Firmware version:E402/ID44
DVD All Regions :Yes
DVD raw data read :yes
DVD raw metadata :Yes
Unrestricted read speed Yes
K92311b2p wrote: Mon Aug 04, 2025 7:37 pm I also have this drive and am looking to flash if possible . Any help would be greatly appreciated.I am not sure I am requesting this correctly if not please advise.
Drive information
Manufacturer:Asus
Product: BW-12D1S-u
Revision:E402
Status enabled
PM sent. No. You have currently a 209.
andrsheep
Post by andrsheep »
Can I get the firmware also?
andrsheep wrote: Tue Aug 05, 2025 2:57 am Can I get the firmware also?
PM sent.
andrsheep
Post by andrsheep »
Getting the following error:
andrsheep wrote: Wed Aug 06, 2025 12:37 am Getting the following error:
Which error? Did you make sure no disc in drive and tray is closed?
andrsheep
Post by andrsheep »
You were right, there was a disc in the tray I did not know about.
It worked great after that1
Thank you,
Andrew
A Murder of Crows
Post by A Murder of Crows »
ello all
sorry to necro this, but i think i've got the same drive with the same issue. could i get this firmware also?
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
Serial number: MCDL023887WL
A Murder of Crows wrote: Sun Aug 24, 2025 5:41 am ello all
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E301
PM sent.
A Murder of Crows
i think i missed it with the chaos of return to office at work :-(
what's the chances of getting it again?
A Murder of Crows
Coopervid wrote: Sun Aug 24, 2025 9:35 am
PM sent.
Hello Coopervid!
i missed the the PM and it looks like it got removed. could i possibly get that again? i didn't receive a notification that you had responded or PM'd, and work has been nuts with return to office requirements the last month.
really sorry for the inconvenience.
A Murder of Crows wrote: Tue Sep 30, 2025 1:26 pm
PM sent.
Hello Coopervid!
I really dislike if people asking for something and then they don't check their PMs. I always delete unread PMs after 2 weeks. You have a new one and I hope you show your appreciation.
