Is the Pioneer BDR209-EBK Flashable for UHD compatibility?
RippingPoetic
Re: Is the Pioneer BDR209-EBK Flashable for UHD compatibility?
Post by RippingPoetic »
Caught in the Pioneer firmware update issue. Is it possible to flash this drive for UHD compatibility?
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.55
Serial number: NCDL001611WL
Firmware date: 2023-02-16
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: Pioneer RS8600
Firmware version: ID60
RippingPoetic wrote: Sun Jun 29, 2025 6:05 am Caught in the Pioneer firmware update issue. Is it possible to flash this drive for UHD compatibility?
OS device name: I:
Revision: 1.55
nope ruined for now i think you emailed me about this already
nd4spd81
Post by nd4spd81 »
IS it possible on these two drives?
Current profile: DVD-ROM
Product: BD-RW BDR-209D
Revision: 1.34
Serial number: ********
Firmware date: 2016-04-25
Highest AACS version: 82
Drive platform: RS8600
Firmware version: 1.34/ID61
And this one?
Revision: 1.30
Serial number: NDDL031745WL
Firmware date: 2014-12-05
Firmware version: 1.30/ID61
nd4spd81 wrote: Wed Aug 20, 2025 2:52 am IS it possible on these two drives?
Revision: 1.34
And this one?
Revision: 1.30
yes just email me that info and i will send you a flasher see below
SvenD
Post by SvenD »
I just started ripping my DVD and BluRay collection and will also eventually buy some 4k UHD BluRays so I'd like to be able to back up those as well.
I have a Pioneer BDR 209-EBK as well which works fine for DVDs and BluRays and I'd like to flash it for the UHD disks.
Are there any disadvantages in flashing it now before I have any UHD disks to rip? I'd just like to be ready for it when i need it.
My drive info from MakeMKV:
OS device name: /dev/rdisk2
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Firmware version: 1.20/ID60
SvenD wrote: Sun Sep 07, 2025 2:28 pm Hi,
Revision: 1.20
Serial number:
No disadvantages. PM sent.
joejunior253
Post by joejunior253 »
Coopervid wrote: Sun Sep 07, 2025 6:39 pm
Revision: 1.20
Serial number:
Hey there, I saw the ultimate guide but didnt see my drive listed. Can I get a PM as well? Here is my specs:
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number:
Firmware date: 2013-09-10
Highest AACS version: 66
Firmware version: E401/ID44
joejunior253 wrote: Mon Sep 15, 2025 7:14 am
Revision: 1.20
Serial number:
OS device name: E:
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E401
Serial number:
PM sent.
DarksideAssembly88
Post by DarksideAssembly88 »
Hi everyone. I've been following this thread (unregistered) and I bought a Pioneer BDR-209EBK from a South African retailer. MakeMKV gives me the following info:
Revision: 1.50
Serial number: QLDL000059WL
Firmware date: 2017-12-21
Drive platform: Pioneer RS8601
I'm running the drive through a Vantec NexStar DX USB 3.0 enclosure, but I can plug directly into my motherboard via SATA and run it that way.
Please send me a PM for an automatic flash kit.
Thank you in advance for your trouble and thank you for the great work that you're doing.
DarksideAssembly88 wrote: Tue Sep 16, 2025 2:12 pm Hi everyone. I've been following this thread (unregistered) and I bought a Pioneer BDR-209EBK from a South African retailer. MakeMKV gives me the following info:
Revision: 1.50
Sure just send that drive info to my email below
DarksideAssembly88
E-mailed Billycar11 and he sorted me out. Works brilliantly, thank you!
ajwhitlock
Post by ajwhitlock »
Hi there. I'm looking for help unlocking the following drive:
OS device name: E:
Revision: 1.34
Serial number: NFDL015081WL
Highest AACS version: 77
Firmware version: 1.34/ID60
Is this one fully unlockable?
ajwhitlock wrote: Thu Oct 23, 2025 12:41 pm Hi there. I'm looking for help unlocking the following drive:
OS device name: E:
Revision: 1.34
PM sent.
ajwhitlock
Thanks for the help. Donation sent. Can't reply to PM as too new on here!
archchaos
Post by archchaos »
Hi guys, o/ i have the same drive, Pioneer 209-EBK
OS device name: H:
Revision: 1.55
Serial number: QEDL054836WL
Highest AACS version: 57
Firmware version: 1.55/ID60
was wondering if mine is flashable to read uhd discs?
thank you!
