unable to open any new DVD disks
JackFlack
Post by JackFlack »
I have been unable to open any new DVD disks with makemkv 1.18.1 [darwin(arm64-release)]. I'm on MacOS Sequoia 15.5 (apple M4 pro chip makbook). I've tried using this with three newly purchased DVDs and makemkv will open none of them. The disks are not damaged as each will play using VLC.
I get a series of errors like the ones below:
udf: udf_get_node: bad allocation extension size in udf_node
Using LibreDrive mode (v01.0 id=5FB5DFEE2318)
Calculated BUP offset for VTS #0 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #5 does not match one in IFO header.
Any solution other than moving to a different program?
Ezatoka
Re: unable to open any new DVD disks
Post by Ezatoka »
Does it happen with the/a previous version?
https://makemkv.com/download/old/
