Hi!
I wasn't able to decrypt a new Blu-ray disk.
Attaching dump file. Would be very grateful if you could add it to keydb.cfg.
Thank you in advance!
AACS v82 Blu-ray Disc dump submission
- MKB_v82_アンダーニンジャ_D232.tgz
- (112.08 KiB) Downloaded 136 times
Re: AACS v82 Blu-ray Disc dump submission
The latest KeyDB contains now a record for this disc.
If you download it and put it in your MakeMKV data directory you should be able to rip it.
I sincerely appreciate your assistance.
Although it took a bit more time than usual to begin, the process was completed successfully in the end.
Thank you again for your help.
