transformers 2007 uhd
leighdog
#1 Post by leighdog » Sat Jun 28, 2025 3:14 am
hello im having dramas with my transformers 2007 film disc , makemkv doesnt like it , it stops about 17 to 20 gb into the backup , this is the only disc ive had problems with , i admit i havnt been using makemkv very long & not very experienced with the program , but was hoping of someone help me with pointing me in the right direction to figure this problem out . thanks
Re: transformers 2007 uhd
#2 Post by dcoke22 » Sat Jun 28, 2025 11:36 am
leighdog wrote: Sat Jun 28, 2025 3:14 am hello im having dramas with my transformers 2007 film disc , makemkv doesnt like it , it stops about 17 to 20 gb into the backup , this is the only disc ive had problems with , i admit i havnt been using makemkv very long & not very experienced with the program , but was hoping of someone help me with pointing me in the right direction to figure this problem out . thanks
Can you copy & paste the MakeMKV log (the bottom half of the screen) of trying to rip that disc into the forum?
The most common suggestion is to gently clean the disc and try again.
leighdog
#3 Post by leighdog » Sun Jun 29, 2025 5:31 am
MakeMKV v1.18.1 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Downloading latest HK to C:\Users\leighdogmsi/.MakeMKV ...
Title #00078.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00099.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00098.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00097.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00096.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00088.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00086.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00084.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00081.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00080.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00079.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00074.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00071.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00072.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00070.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00068.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00087.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00065.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00066.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00064.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00063.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00062.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.mpls has length of 84 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00095.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.mpls has length of 20 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.mpls has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00800.mpls was added as title #0
Title #00091.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00040.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00033.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00032.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00060.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00031.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00020.m2ts was added as title #1
Title #00019.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00011.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 38 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00001.m2ts has length of 45 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 0 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00146.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00145.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00144.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00143.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00142.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00140.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00139.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00138.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00137.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00136.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00135.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00134.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00131.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00130.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00129.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00128.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00127.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00126.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00125.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00124.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00123.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00122.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00119.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00118.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00117.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00116.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00115.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00114.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00113.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00112.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00111.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00110.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00109.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00108.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00107.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00106.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00105.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00104.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00103.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00102.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 16 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory E:/
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '20402860032'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom1' at offset '20402860032'
Failed to save title 0 to file E://Transformers_t00.mkv
Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
0 titles saved, 1 failed
leighdog
#4 Post by leighdog » Sun Jun 29, 2025 5:39 am
hello thanks for helping me , i went and got another brand new disc with no defects on it , & it did the same thing as the last disc , & i copied & pasted the details u asked for , thanks
#5 Post by dcoke22 » Sun Jun 29, 2025 12:46 pm
leighdog wrote: Sun Jun 29, 2025 5:31 am Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00020.m2ts' at offset '20402860032'
That message means the optical drive was unable to correctly read a spot on that disc. The standard advice is to gently clean the disc and try again. Sometimes, even brand new discs can have an almost invisible film on them left over from the manufacturing process or as a result of the plastic case off gassing. Whenever I have to clean a disc, I use plenty of warm water and liquid dish soap and gently scrub the disc with my fingertip moving in a straight line from the inner ring to the outer ring.
It has also been my experience that a different drive might get different results when reading the same disc. If you have a second drive, trying the disc in a different drive might help.
leighdog
#6 Post by leighdog » Sun Jun 29, 2025 1:44 pm
hello , this drive has not ever played up with any film so far before , but thats now 2 brand new discs that have behaved the same way , ive only got the one uhd ripper atm , i will try cleaning the disc tomorrow also , but yes buying another drive or buying a different version of the film would probly be the next step , thanks
leighdog
#7 Post by leighdog » Mon Jun 30, 2025 10:10 am
hello , i tried cleaning the disc , the disc did the same thing & failed once again , i also tried copying the disc contents to a harddrive to then use in makemkv , the harddrive got to about the same spot as the disc about the 17 to 18gb , does this mean its some sort of problem with the files on the disc ? thanks
#8 Post by dcoke22 » Thu Jul 03, 2025 1:55 pm
There's certainly something about that disc that your optical drive doesn't like.
If you want to copy the whole disc to your drive, using MakeMKV's backup function is the best way to do that. On the first screen of MakeMKV, click the icon of the yellow folder with the green arrow at the top. Make sure the decrypted box is checked, pick a location & folder name and let MakeMKV decrypt and copy the contents of a disc to a folder on your hard drive (or an .iso file in the case of a DVD).
leighdog
#9 Post by leighdog » Thu Jul 03, 2025 11:40 pm
hello , thanks for ur reply , ive sent my 2 copies of the film back to the retailer for a refund , they wouldnt play properly from about 30mins into the film . ive ordered a version of the film from the u.k which will be about 2weeks in transport still , hopefully the new version works in some way , thanks
leighdog
#10 Post by leighdog » Tue Jul 22, 2025 7:11 am
hello , just a update on this if anyone encounters a problem like this , i imported a version of the the same film through the u.k to australia (3weeks wait)so it must of been a different print & slightly different version , but it all works now , the 4k disc , rips & plays 100% fine , so it must point the the australian sold version of the disc having some sort of fault within the disc of files setup within the disc , thanks for any help also
