I have been using MakeMKV for a little while now and I've been able to usually find the answers to my questions after some digging.
I've been able to to other 4k's in the past. It's been a little over a year since my last time I have ripped anything.
I am currently trying to rip Wicked Part I and after everything I've done, I've been given the same video can't be decrypted and failed to open disc prompt.
I have an LG BP60NB10 that I purchased in 2023. I've reflashed to 1.02 and ensured I had enc in the prompt, I've uninstalled and reinstalled the app and reflashed again.
OS device name: E:
Product: BD-RE BP60NB10
Revision: 1.02
Serial number:
Firmware date: 2120-05-07 09:35
Highest AACS version: 77
Firmware version: 1.02
I've looked in the AACS tgz dump log file, and after it try's to "load content hash table, will verify intgrity of M2TS files" it starts with the can't decrypt
What am I doing wrong?
BP60NB10 Revision 1.02 4k UHD Failing to Decrypt
Re: BP60NB10 Revision 1.02 4k UHD Failing to Decrypt
Copy & paste the actual log window messages so we can try to help you.MTGplayer wrote: ↑Wed Jun 25, 2025 10:31 pmI have been using MakeMKV for a little while now and I've been able to usually find the answers to my questions after some digging.
OS device name: E:
Revision: 1.02
Serial number:
Below is what I receive anytime I try and read the disc.
Debug log started at Fri Jun 27 20:57:23 2025 , written by MakeMKV v1.18.1 win(x64-release)
001005:0000 MakeMKV v1.18.1 win(x64-release) started
DEBUG: Code 3 at u%~+41nw7Z$>\(rT@7Hdjpjz:29395310
SDF v098: HL-DT-ST_BD-RE_BP60NB10_1.02_212005070935_SIK09O58A5635
001011:0000 Using LibreDrive mode (v06.3 id=4C194CE2C4D1)
DEBUG: Code 2147483648 at 2g`y)1d*msr{}#Bb:121265499
DEBUG: Code 0 at 2g`y)1d*msr{}#Bb:121268443
There should be more to the log than that!!MTGplayer wrote: ↑Fri Jun 27, 2025 8:59 pmBelow is what I receive anytime I try and read the disc.
Are you letting Windows initialize the disc before opening MakeMKV? If not, you should be.
