3D blu-ray to .iso?
tokeL
3D blu-ray to .iso?
Post by tokeL »
I would like to rip 3D blu-rays to .iso with macOS.
And I won't pay for DVDFab. Price is ridiculous for rare use and their kext breaks down the OS every time.
So I guess there is no straight forward app to be found?
Just wondering, if ripping is done with makemkv ie. resulting just the folder structure, does then something go missing when that is wrapped to .iso-image?
What would be the easiest GUI-app that can do UDF2.5?
Or is terminal commands better?
flojo
Re: 3D blu-ray to .iso?
Post by flojo »
.imgburn on Windows. I'm on Linux but, if I wanted to do it right now I'd download Windows 11 from Microsoft.com and run it in Virtualbox, saving the resulting. iSO to a NFS mount.
I"ve read you van do it with BSD, but I never tried.
tokeL
Post by tokeL »
flojo wrote:
Fri May 23, 2025 9:35 pm
I've read you can do it with BSD, but I never tried.
I tried with ImgBurn, but there was an error.
But maybe the problem was the bd-drive.
I'll try with other drive...
I thought that ancient (last version 12 years ago...) ImgBurn could not read 3D-blu-rays...
tokeL
Post by tokeL »
I'm newbie on this forum, so I can't add to my reply before it's approved.
So, I continue:
Is your advice rip with makemkv "backup disk" and then convert it to .iso with ImgBurn?
Actually, there were many rippers that failed in windows to rip the disc.
As an example, BR2049-3d rip with makemkv has 4 folders and one big BDMV file. All those to .iso-image with ImgBurn?
flojo
Post by flojo »
tokeL wrote:
Wed May 28, 2025 5:53 pm
... rip with makemkv "backup disk" and then convert it to .iso with ImgBurn?
Yes, rip with MakeMKV then use imgburn. Yes you put all the files from the root of the disc to the root of the image.
I *think* only DVDFab will save directly to a .iso. Obviously if the files required to run the BD menus are not present/corrupt, then the player will not start or crash. That 1 big file is probably the entire movie, which you *could* use 1 of those trial-ware programs to create a new menu(s) or maybe use another disc's menus... although I'm not sure if that works, which would be like running the menus from Wizard of Oz but swapping the .m2ts file out for Pulp Fiction.
You really should think about using .zip instead of .iso. To be honest, if players had better support for either then this probably wouldn't be a issue for anything including .tar, 7z, xz etc. But it seems players haven't implemented a mutable interface for anything other than single files, so saving resume times, custom chapters, etc. is still not possible.
tokeL
Post by tokeL »
Wanting to save the disc as .iso is for future proof.
The image should be identical representation fo the disc.
It's a bit strange tat there is only one software in the world that can do that and the company is quite shady.
But if it's so, then it is.
"Reality is that which, when you stop believing in it, doesn't go away"
Thanks @flojo for your answer.
flojo
Post by flojo »
tokeL wrote:
Thu Jun 26, 2025 9:51 pm
I don't think it is here, I think that's a hang over belief from the CD-ROM days where ripping was treating the drive as a block device and bytes were read "raw" and the LBA was replicated to combat the lazy copy protection of magic sector addresses. However, from everything I've read, DVD and Blu-ray data is read via the filesystem. *If* I'm right, then the usage of a .iso is a facade and one of, if not the worst archiving "containers" you can use (especially a UDF 2.5 FS).
tokeL
Post by tokeL »
It is still handy to have always one disc as one file.
differowner
Post by differowner »
tokeL wrote:
Thu May 22, 2025 2:19 pm
Use MakeMKV to rip the 3D Blu-ray to folder, nothing is lost when wrapping into ISO, and on macOS you can create a UDF 2.5 ISO via `hdiutil` in Terminal more reliably than with GUI apps.
bloodmoney horror game
differowner wrote:
Wed Sep 17, 2025 3:40 am
I'm curious how? When I look at the docs for hdiutil it seems it only does UDF 1.02 or 1.5. At least, that's what reading the help on the 'makehybrid' verb seems to suggest.
