#16 Post by Coopervid » Sun May 04, 2025 9:39 am
edmsms wrote: Sun May 04, 2025 1:55 am Same model: ASUS SBW-06D5H-U. It can be flashed?
PM sent.
edmsms
#17 Post by edmsms » Thu May 22, 2025 4:00 am
Coopervid wrote: Sun May 04, 2025 9:39 am
PM sent.
Thanks man, this worked 100%. Is it possible to do something similar with this drive?
Captura de tela 2025-05-22 005947.png (11.22 KiB) Viewed 52282 times
#18 Post by Coopervid » Wed Jun 04, 2025 4:48 am
edmsms wrote: Thu May 22, 2025 4:00 am
PM sent.
No.
edmsms
#19 Post by edmsms » Tue Jun 10, 2025 9:49 am
Coopervid wrote: Wed Jun 04, 2025 4:48 am
PM sent.
No.
Hey, just passing by to thank you and everyone on this site, especially: Pat LaVarre, >NIL:, Agent Smith, Liggy, Mike Chen, ala42, czary2mary, jadburner, cvs, alexx12345, seku, Leman39, wujooj, jurireal, alphaville0527, SnowFox, Kirby, haysey70, Majestic12, elflorek, floppydumper, redwine, cryptojoe3737, TeddyRaspin, Billycar11, asmcom, Coopervid (thanks again), payalnik23, and aliter404.
Later, after reading the pinned post, I discovered that this drive was too old to be flashed, but with my third drive (WH14NS40), I managed to flash it to ---> WH16NS60. Thanks again, everyone. You’re awesome!
Just one question: I noticed that there are 3 different programs to flash the drives (BDRFlash, makemkvcon, and SDFGUI). All three worked correctly, but I just want to know if there are any differences between them. Thanks again, folks! :D
#20 Post by Coopervid » Wed Jun 11, 2025 1:47 pm
edmsms wrote: Tue Jun 10, 2025 9:49 am
No.
There is BDRFlash for Pioneer drives. Makekmvcon and the GUI for it written by Marty is SDFTool which uses Makemkvcon for LG / ASUS drives.
draughthorse
#21 Post by draughthorse » Fri Jun 13, 2025 7:50 pm
hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
#22 Post by Coopervid » Sun Jun 22, 2025 2:11 pm
draughthorse wrote: Fri Jun 13, 2025 7:50 pm hi, i was wondering if my ASUS SBW-06D5H-U is flashable?
Yes. Use SDFTool and flash to BU40N.
draughthorse
#23 Post by draughthorse » Sun Jun 22, 2025 9:55 pm
Coopervid wrote: Sun Jun 22, 2025 2:11 pm
are you sure... im reading the uhd drive flashing guide and it tells me specifically not to crossflash between asus and lg because it will brick my drive. is there something im missing?
#24 Post by Coopervid » Mon Jun 23, 2025 7:12 pm
draughthorse wrote: Sun Jun 22, 2025 9:55 pm
Yes. It's a slim drive. The warning is meant not to flash firmware of full size drives to slim drives and vice versa
sid87
#25 Post by sid87 » Thu Jun 26, 2025 9:27 pm
Hi! I've also the same model, I'd like to know if mine can be flashed:
Captura de pantalla 2025-06-26 232538.png (34.55 KiB) Viewed 50501 times
#26 Post by Billycar11 » Fri Jun 27, 2025 6:14 am
sid87 wrote: Thu Jun 26, 2025 9:27 pm Hi! I've also the same model, I'd like to know if mine can be flashed:
sure email me that drive info below
draughthorse
#27 Post by draughthorse » Fri Jun 27, 2025 10:01 am
Coopervid wrote: Mon Jun 23, 2025 7:12 pm
thanks, ive tested it and it works :D
davinci247
#28 Post by davinci247 » Tue Jul 08, 2025 8:59 pm
Hi all,
I have this drive model also. Does it Support 4K Blurays out of the box, or do I need to flash it? If so, where do I find the correct firmware?
OS device name: /dev/rdisk4
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: SCDL117238WL
Firmware date: 2018-08-22
Highest AACS version: 76
Drive platform: RS8511
Firmware version: E101/ID26
#29 Post by Coopervid » Tue Jul 08, 2025 9:42 pm
davinci247 wrote: Tue Jul 08, 2025 8:59 pm Hi all,
Manufacturer: ASUS
Revision: E101
PM sent for flashing it
davinci247
#30 Post by davinci247 » Thu Jul 17, 2025 8:56 pm
thanks! Just got around to flashing now, worked just fine :)
cheers!
