Avatar - 800.mpls or 801.mpls?
wesg92
Post by wesg92 »
Hi all,
I don't know how to choose when there are 2 identical tracks, with only the segment map that differs (at least from what I can tell).
Anyone know the differences?
Also, if this is similar for Avatar: The Way of Water, let me know, as that one is next.
Toad King
Re: Avatar - 800.mpls or 801.mpls?
Post by Toad King »
Check the audio and subtitle tracks. Those separate playlists are usually for different regions. Just pick the one that has the languages you want, or 800 if both have them since that's usually the US one.
wesg92
Post by wesg92 »
Audio and subtitle tracks are identical
jinx100
Post by jinx100 »
Try looking at the "frequently asked questions"
viewtopic.php?f=1&t=24388
