BDR-XS07S UHD Flash
pspice2k
Re: BDR-XS07S UHD Flash
Post by pspice2k »
Hi Coopervid,
Is my drive able to be flashed or do I have to wait:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.03
Serial number: ----
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: Pioneer RS8E20
Firmware version: GENE
pspice2k wrote: Tue Jun 24, 2025 2:04 am Hi Coopervid,
OS device name: G:
Revision: 1.03
Serial number: ----
You gotta wait.
required9001
Post by required9001 »
I have a drive I would like to flash, is there a repository of firmware I can use with this drive?
OS device name: G:
Revision: 1.01
Serial number:
Firmware date: 2020-09-03
Drive platform: RS8E20
Firmware version: 1.01
required9001 wrote: Thu Jun 26, 2025 3:29 am Hello,
OS device name: G:
Revision: 1.01
Serial number:
PM sent.
draughthorse
Post by draughthorse »
hi, i was wondering if my bdr-xd07s is flashable? firmware date seems early enough, 2020
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Drive platform: RS8D30
Firmware version: 1.03
draughthorse wrote: Mon Jun 30, 2025 12:01 pm hi, i was wondering if my bdr-xd07s is flashable? firmware date seems early enough, 2020
Revision: 1.03
Serial number:
Yes. PM sent.
haws24
Post by haws24 »
I appreciate all the work that has been done here. It seems like I should be good to flash this one based on what I read in this thread. Her is my info.
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: *******
Firmware date: 2019-01-07
Highest AACS version: 77
Drive platform: RS8E21
Firmware version: 1.00/ID05
haws24 wrote: Mon Jun 30, 2025 7:13 pm I appreciate all the work that has been done here. It seems like I should be good to flash this one based on what I read in this thread. Her is my info.
OS device name: E:
Revision: 1.00
PM sent.
haws24
Post by haws24 »
Thanks for the quick reply. Worked like a charm. I'm up and ripping UHD again.
wilchu
Post by wilchu »
Hello, I would like to flash my drive to be able to read UHD disks, looking at the previous replies it should be possible, some more info below:
OS device name: /dev/sr2
Revision: 1.03
Serial number:
Highest AACS version: 19
wilchu wrote: Wed Jul 02, 2025 6:29 pm Hello, I would like to flash my drive to be able to read UHD disks, looking at the previous replies it should be possible, some more info below:
Revision: 1.03
Serial number:
PM sent.
JDPlug
Post by JDPlug »
Good day, I would also like to flash my drive for UHD discs.
Revision: 1.01
Serial number:
Highest AACS version: 68
JDPlug wrote: Sun Jul 06, 2025 8:53 am Good day, I would also like to flash my drive for UHD discs.
Revision: 1.01
Serial number:
PM sent.
jdisles
Post by jdisles »
Could I trouble you for instructions on how to flash my drive for UHD discs?
Revision: 1.01
Serial number:
Highest AACS version: 31
Thank you in advance for your help.
jdisles
jdisles wrote: Tue Jul 08, 2025 11:56 pm Could I trouble you for instructions on how to flash my drive for UHD discs?
Revision: 1.01
Serial number:
jdisles
PM sent.
