Hi!
I wasn't able to decrypt a new Blu-ray disk.
Attaching dump file. Would be very grateful if you could add it to keydb.cfg.
Thank you in advance!
[SOLVED]AACS v82 Blu-ray Disc dump submission
- MKB_v82_EYXF_14678_D080.tgz
- (106.22 KiB) Downloaded 79 times
- MKB_v82_EYXF_14677_351A.tgz
- (97.98 KiB) Downloaded 77 times
- MKB_v82_EYXF_14676_25F8.tgz
- (97.86 KiB) Downloaded 75 times
honkbasalt
- Contact:
Re: AACS v82 Blu-ray Disc dump submission
Look up the exact running time of the Now You See Me Extended Edition Blu-ray disc on sites like Blu-ray.com, IMDb, or Wikipedia. In your ripping software (like MakeMKV), compare the listed running times of the different playlists. The exact running time will most likely match the official running time. For Now You See Me Extended Edition, the running time is approximately 2:09:34 (2 hours, 9 minutes, 34 seconds). This is important information for determining the correct playlist.
Thank you so much! I can decrypt my disc now.
