BDR-XS07S UHD Flash
pspice2k
Re: BDR-XS07S UHD Flash
#211 Post by pspice2k » Tue Jun 24, 2025 2:04 am
Hi Coopervid,
Is my drive able to be flashed or do I have to wait:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-XS07
Revision: 1.03
Serial number: ----
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: Pioneer RS8E20
Firmware version: GENE
#212 Post by Coopervid » Tue Jun 24, 2025 12:55 pm
pspice2k wrote: Tue Jun 24, 2025 2:04 am Hi Coopervid,
OS device name: G:
Revision: 1.03
Serial number: ----
You gotta wait.
required9001
#213 Post by required9001 » Thu Jun 26, 2025 3:29 am
I have a drive I would like to flash, is there a repository of firmware I can use with this drive?
OS device name: G:
Revision: 1.01
Serial number:
Firmware date: 2020-09-03
Drive platform: RS8E20
Firmware version: 1.01
#214 Post by Coopervid » Thu Jun 26, 2025 5:43 pm
required9001 wrote: Thu Jun 26, 2025 3:29 am Hello,
OS device name: G:
Revision: 1.01
Serial number:
PM sent.
draughthorse
#215 Post by draughthorse » Mon Jun 30, 2025 12:01 pm
hi, i was wondering if my bdr-xd07s is flashable? firmware date seems early enough, 2020
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Drive platform: RS8D30
Firmware version: 1.03
#216 Post by Coopervid » Mon Jun 30, 2025 12:28 pm
draughthorse wrote: Mon Jun 30, 2025 12:01 pm hi, i was wondering if my bdr-xd07s is flashable? firmware date seems early enough, 2020
Revision: 1.03
Serial number:
Yes. PM sent.
haws24
#217 Post by haws24 » Mon Jun 30, 2025 7:13 pm
I appreciate all the work that has been done here. It seems like I should be good to flash this one based on what I read in this thread. Her is my info.
OS device name: E:
Product: BD-RW BDR-XS07U
Revision: 1.00
Serial number: *******
Firmware date: 2019-01-07
Highest AACS version: 77
Drive platform: RS8E21
Firmware version: 1.00/ID05
#218 Post by Coopervid » Tue Jul 01, 2025 9:39 am
haws24 wrote: Mon Jun 30, 2025 7:13 pm I appreciate all the work that has been done here. It seems like I should be good to flash this one based on what I read in this thread. Her is my info.
OS device name: E:
Revision: 1.00
PM sent.
haws24
#219 Post by haws24 » Tue Jul 01, 2025 7:51 pm
Thanks for the quick reply. Worked like a charm. I'm up and ripping UHD again.
wilchu
#220 Post by wilchu » Wed Jul 02, 2025 6:29 pm
Hello, I would like to flash my drive to be able to read UHD disks, looking at the previous replies it should be possible, some more info below:
OS device name: /dev/sr2
Revision: 1.03
Serial number:
Highest AACS version: 19
#221 Post by Coopervid » Thu Jul 03, 2025 9:30 am
wilchu wrote: Wed Jul 02, 2025 6:29 pm Hello, I would like to flash my drive to be able to read UHD disks, looking at the previous replies it should be possible, some more info below:
Revision: 1.03
Serial number:
PM sent.
JDPlug
#222 Post by JDPlug » Sun Jul 06, 2025 8:53 am
Good day, I would also like to flash my drive for UHD discs.
Revision: 1.01
Serial number:
Highest AACS version: 68
#223 Post by Coopervid » Mon Jul 07, 2025 10:13 am
JDPlug wrote: Sun Jul 06, 2025 8:53 am Good day, I would also like to flash my drive for UHD discs.
Revision: 1.01
Serial number:
PM sent.
jdisles
#224 Post by jdisles » Tue Jul 08, 2025 11:56 pm
Could I trouble you for instructions on how to flash my drive for UHD discs?
Revision: 1.01
Serial number:
Highest AACS version: 31
Thank you in advance for your help.
jdisles
#225 Post by Coopervid » Wed Jul 09, 2025 6:44 pm
jdisles wrote: Tue Jul 08, 2025 11:56 pm Could I trouble you for instructions on how to flash my drive for UHD discs?
Revision: 1.01
Serial number:
jdisles
PM sent.
