michealespinola
Re: SDFtool Flasher
#1366 Post by michealespinola » Tue Jun 10, 2025 9:33 pm
MartyMcNuts wrote: Sat Jan 08, 2022 1:21 am The GUI may look a bit deformed if you are using a 4K monitor. You can right click the exe and select properties. In the compatibility tab, click "Change high DPI settings" then under "High DPI scaling override" tick the box and select "System (Enhanced)" in the dropbox.
This was a life-saver comment. Thank you!
DigitalArchivist
Re: SDFtool Flasher
#1367 Post by DigitalArchivist » Thu Jun 12, 2025 5:31 am
Hi all — I’m hoping someone can help me recover from a flashing error.
I accidentally flashed slim drive firmware (WP50NB40) onto my ASUS BW-16D1HT. The drive is now soft-bricked — it identifies as WP50NB40 1.03, and I can no longer flash anything else to it. “Write flash” throws error 0xff05c103, and “Recover Drive” doesn’t work either. The drive is still seen in Windows and MakeMKV, but no flashing tool accepts the model mismatch.
I’ve tried renaming the firmware, using SDFTool and ASUS_ODD_FW_Changer, rebooting, and unplugging—no change. I do not have a firmware dump.
Does anyone have a method to reflash a BW-16D1HT that’s been misflashed with a slim drive identity?
Appreciate any help you can offer.
—Tim (Honolulu)
Tim Williams – Honolulu, HI | ASUS BW-16D1HT (bricked via slim flash) | Mac Studio M1 + MacBook Air M3 | UGREEN NASync DXP2800 | Building personal media archive via MakeMKV, Plex, and SSD/HDD NAS
Re: SDFtool Flasher
#1368 Post by MartyMcNuts » Fri Jun 13, 2025 12:31 am
DigitalArchivist wrote: Thu Jun 12, 2025 5:31 am Hi all — I’m hoping someone can help me recover from a flashing error.
—Tim (Honolulu)
The recover option was made for this exact reason so should work if you do it correctly. First, ensure there is no disc in the drive and the tray is closed.
Select the drive.
Select RECOVER.
In the popup window, select the exact firmware you currently have on the drive. In your case, WP50NB40 1.03 MK (I assume you used the MK firmware)
In the firmware selection drop down box, select the BW-16D1HT 3.10-MK firmware.
Press START.
The process should take around 45 seconds and should work. I've done it before.
If you still can't get it to work, you could try using the old modified ASUS flasher as it does not perform any checks at all and may be able to flash the drive with BW-16D1HT 3.10-MK firmware.
IRRDC
Re: SDFtool Flasher
#1369 Post by IRRDC » Fri Jun 13, 2025 6:37 am
three month ago I bought a Hitachi-LG BU40N Internal and flashed it to the 1.03 firmware and everything was working wonderfully. Now suddenly it won't recognice DVDs, Blu-rays and UHDs, just CDs show up as inserted. I guess it's not a firmware problem, so I want to return the drive. It came with firmware version 1.04. It seems I did not make a dump of that before flashing the drive.
Is version 1.04 available somewhere? On the Hitachi-LG website I only found an "auto firmware update" tool. Will the flash be detectable if I return to 1.04 before returning the drive?
STRAINEDCAT
Re: SDFtool Flasher
#1370 Post by STRAINEDCAT » Sun Jun 22, 2025 1:09 am
Hey can you guys help me flash this?
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number:
Firmware date: 2120-12-02 11:14
Bus encryption flags: 1F
Re: SDFtool Flasher
#1371 Post by MartyMcNuts » Sun Jun 22, 2025 2:27 am
IRRDC wrote: Fri Jun 13, 2025 6:37 am Hi,
You can just flash it with BU40N 1.04-MK
Devin
Re: SDFtool Flasher
#1372 Post by Devin » Fri Jul 04, 2025 6:44 pm
Dear person in question,
I've downloaded the SDL GUI. But when I try and open it, the program says that I need MakeMKV Installed. But I installed it. What should I do?
Re: SDFtool Flasher
#1373 Post by MartyMcNuts » Sat Jul 05, 2025 1:30 am
Devin wrote: Fri Jul 04, 2025 6:44 pm Dear person in question,
Install MakeMKV in the default location: "C:\Program Files (x86)\MakeMKV"
Jentan47
Re: SDFtool Flasher
#1374 Post by Jentan47 » Sun Jul 20, 2025 8:42 pm
Hi, Can I use the GUI Sdf Tool LG BU40N Firmware 1.03 MK for a BU40N Firmware 1.05 - or is there a separate version available for Vers. 1.05??
Would be grateful for your help.
Jens T
Re: SDFtool Flasher
#1375 Post by MartyMcNuts » Sun Jul 20, 2025 11:11 pm
Jentan47 wrote: Sun Jul 20, 2025 8:42 pm Hi, Can I use the GUI Sdf Tool LG BU40N Firmware 1.03 MK for a BU40N Firmware 1.05 - or is there a separate version available for Vers. 1.05??
Jens T
Yes, 1.03-MK.
Jentan47
Re: SDFtool Flasher
#1376 Post by Jentan47 » Mon Jul 21, 2025 8:48 am
Great, thanks! 🙂
Jentan47
Re: SDFtool Flasher
#1377 Post by Jentan47 » Tue Jul 22, 2025 10:50 am
DE_LG_BU40N_1.03_MK-bin: Does this GUI not work on Mac OS??
"Cannot expand...It has a format that is not supported."
Is there a separate file for Mac?
Jens T 😊
Re: SDFtool Flasher
#1378 Post by Coopervid » Tue Jul 22, 2025 1:02 pm
Jentan47 wrote: Tue Jul 22, 2025 10:50 am DE_LG_BU40N_1.03_MK-bin: Does this GUI not work on Mac OS??
Jens T 😊
SDFTool flasher is Windows only. On a Mac you need to use the command line or a VM for SDFTool. Read this:
viewtopic.php?f=16&t=19634
"How to flash videos and commands"
HerrNerdstrom
Re: SDFtool Flasher
#1379 Post by HerrNerdstrom » Fri Aug 01, 2025 3:40 am
I just flashed my LG WH16NS40 to DE_LG_WH16NS60_1.02_MK per instructions because the original firmware was encrypted. The instructions say that I can now flash to another firmware if I choose. Why would I want that? What are the benefits of a different firmware? The only version I could see that matches is the DE_LG_WH16NS40-NS50_1.02.
Thanks.
zittrig
Re: SDFtool Flasher
#1380 Post by zittrig » Fri Aug 01, 2025 4:57 am
It's an option, no need. Better have and do not need than need and do not have. :wink:
The WH16NS60 1.02MK is the recommended firmware for your drive. But theoretically, there could be a better firmware in the future.
