Hi I am facing a problem decrypting an AACS v82 Blu-ray disc.
Here is the .tgz file.
Appreciate if someone can help to update in keydb.
Thanks in advance!
[Solved, thank you!] Decrypt AACS v82 disc
Re: Decrypt AACS v82 disc
The latest KeyDB contains a record for this disc. Please download it and put it in your MakeMKV data directory (where the TGZ dumps are generated) and you should be able to rip it.hed217 wrote: Thu Jun 19, 2025 10:25 pm Hi I am facing a problem decrypting an AACS v82 Blu-ray disc.
Thanks in advance!
Successfully ripped the disc. Thank you so much
How does one do that?MartyMcNuts wrote: Fri Jun 20, 2025 3:12 am The latest KeyDB contains a record for this disc. Please download it and put it in your MakeMKV data directory (where the TGZ dumps are generated) and you should be able to rip it.
Download from http://fvonline-db.bplaced.net/
Tkx. I did that, let me rip the disc.
Do I need to extract the keydb.cfg from the archive when I place it in my MakeMKV data directory?MartyMcNuts wrote: Fri Jun 20, 2025 3:12 amThe latest KeyDB contains a record for this disc. Please download it and put it in your MakeMKV data directory (where the TGZ dumps are generated) and you should be able to rip it.hed217 wrote: Thu Jun 19, 2025 10:25 pm Hi I am facing a problem decrypting an AACS v82 Blu-ray disc.
Thanks in advance!
Yes.hbk4ever wrote: Sat Jun 21, 2025 2:03 pmDo I need to extract the keydb.cfg from the archive when I place it in my MakeMKV data directory?MartyMcNuts wrote: Fri Jun 20, 2025 3:12 amThe latest KeyDB contains a record for this disc. Please download it and put it in your MakeMKV data directory (where the TGZ dumps are generated) and you should be able to rip it.hed217 wrote: Thu Jun 19, 2025 10:25 pm Hi I am facing a problem decrypting an AACS v82 Blu-ray disc.
Thanks in advance!
