MKB20_v82_The_Monkey_198E.tgz
File sent via email.
The Monkey UHD
keydb_helper
Re: The Monkey UHD
Thanks for providing a suitable disc dump file. The 198E variant of The Monkey has been added to the public keydb.tritop wrote: Sat Jun 21, 2025 12:27 pm Hi,
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
