Filename
unique24
Filename
Post by unique24 »
Hello
I purchase today the software and are happy with it.
But there is one point I think it could be better:
The Outputfile name is always title01, title02, ...
I always have to rename the files.
Wouold be great if we can set a Filename with variable ... so "Columbo 01x{##}" for example will generate:
Columbo 01x01
Columbo 01x02
Columbo 01x03
The start count should be able to set.
Thank you!
Re: Filename
Post by mike admin »
With 1.7.0 you can rename files in GUI, if you enable expert mode.
unique24
Re: Filename
Post by unique24 »
Hello
Oh, thank you!
But I have to rename each file.
is it possible to set for the first file the name and the next are counting up (Only the selected)?
Thank you!
Chetwood
Re: Filename
Post by Chetwood »
I also think it's weird not to have it the usual way: use a proper filename instead of a folder name with a title.mkv inside.
Why not use the BD's parent directory filename by default? Well, gonna try advanced mode as soon as 1.7x is fixed.
