PM sent.Matista217 wrote: Mon Jun 16, 2025 5:57 am Tapping in! very excited to now DUAL WIELD UHD RIPPING
Manufacturer: PIONEER
Product: BD-RW BDRUD03AS
Revision: 1.00
Serial number: ----
Firmware date: 2014-04-01
Highest AACS version: 81
Drive platform: Pioneer RS8510
Firmware version: ID23
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Hi !! Can you help me with my UD03?
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 78
Drive platform: RS8511
Firmware version: 1.14
Revision: 1.14
Serial number:
PM sent.Player125 wrote: Fri Jun 20, 2025 7:50 pm Hi !! Can you help me with my UD03?
Revision: 1.14
Serial number:
Sorry!! for my very Late response...Coopervid wrote: Thu Jun 12, 2025 7:31 pmPM sent.FRG39 wrote: Thu Jun 12, 2025 3:35 pm Hi
I have a PIONEER BDR-US03 drive branded as Verbatim.
Today I tried to use a UHD movie on it but get a "no disc " error when inserting discs.
I googled and reached this forum, Please how do I go about flashing it to read UDH discs?
Any help appreciated. My Drive MakeMKV info is below
OS device name: F:
Revision: 1.14
Serial number: -------------
Thank you so much! for the Firmware patch, small donation sent...
UHD disc are now readable in the Drive but MakeMKV still shows "Firmware type: Original (unpatched)", Also PowerDVD still doesn't play the Bluray Movie Discs,
After some googleing got a alternative "Leawo Blu-ray Player" which seems to play the movies with Menu's Has any one used this software any reviews on it....
But would love if I could get PowerDVD to play the disc, any suggestions??
OS device name: F:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: --------------
Highest AACS version: 61
Drive platform: RS8A10
Use Google. This is the Makemkv forum.
PowerDVD will never be able to play UHD discs as they removed this ability a couple of years ago.FRG39 wrote: Sat Jun 21, 2025 2:59 pmSorry!! for my very Late response...Coopervid wrote: Thu Jun 12, 2025 7:31 pmPM sent.FRG39 wrote: Thu Jun 12, 2025 3:35 pm Hi
OS device name: F:
Revision: 1.14
OS device name: F:
Revision: 1.14
So any alternative recommendations for playing UHD discs with menu support?
Makemkv+ vlc can do itFRG39 wrote: Sun Jun 22, 2025 12:02 pmoh
Thanks , will try that. Hope it can ply with menu support...
harold1967
Hi
Can you please share patch for the Pioneer/Verbatim BDR-UD03 firmware 1.1?
Harold
Harold
Post your Makemkv info.harold1967 wrote: Thu Jun 26, 2025 7:46 am Hi
Harold
harold1967
Sorry:Coopervid wrote: Thu Jun 26, 2025 7:56 pmPost your Makemkv info.harold1967 wrote: Thu Jun 26, 2025 7:46 am Hi
Harold
OS device name: E:
Revision: 1.10
Serial number:
Firmware date: 2017-04-18
Highest AACS version: 77
Firmware version: 1.10
PM sent.harold1967 wrote: Fri Jun 27, 2025 12:26 pmSorry:Coopervid wrote: Thu Jun 26, 2025 7:56 pmPost your Makemkv info.harold1967 wrote: Thu Jun 26, 2025 7:46 am Hi
Harold
OS device name: E:
Revision: 1.10
Serial number:
roundmidnight
Hello I just bought a Verbatim with a Pioneer UD03. Could I have a copy of the firmware patch? Thanks!
OS device name: /dev/sr1
Revision: 1.14
Serial number:
Highest AACS version: 76
Revision: 1.14
Serial number:
