No. You will need a good VM with Windows like VMWare.
BDR 212V UHD Guide
Re: BDR 212V UHD Guide
bill_w
What version of Windows is required? I have an old XP VM. Will that work?
It should.bill_w wrote: Fri Jun 20, 2025 6:01 pm What version of Windows is required? I have an old XP VM. Will that work?
PM sent.Perdido wrote: Fri Jun 20, 2025 1:14 am Hi, like PlayMeAGroove I bought a bunch of Pioneer drives while I can, I might even get a few more later.
May I please have upgrades for these four drives:
Drive 1
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.02/ID61
Drive 2
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: AEDL010899WL
Firmware date: 2020-07-21
Firmware version: 1.01/ID56
Drive 3
Revision: 1.00
Serial number:
Firmware date: 2019-01-10
Firmware version: 1.00/ID61
Drive 4
Revision: 1.01
Serial number:
Grateful for the terrific help!
PM sent.Mikin wrote: Fri Jun 20, 2025 8:41 am Hello @Coopervid,
Could you please help me flash my BDR-212V to read UHD?
Here is my drive info:
OS device name: \Device\CdRom2
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-05-31
Highest AACS version: 77
Firmware version: ID06
Best Regards
calebhodge72
Hi @Coopervid,
Thanks for all the help you've provided to everyone here on the forums. You're a legend. Could I also get a PM for my BDR-212V to read UHD?
Drive info:
Also, if I get another BDR-212V in the future, will I be able to re-use the flasher you send? Or is it tied to a specific firmware date, bus encryption flag, or AACS version?
Drive info:
OS device name: F:
Revision: 1.02
Firmware version: ID06-
harfdorkinson
Hey @Coopervid, you sound like the most helpful of folks to make my fresh BDR-212V read UHD:
Revision: 1.02
Serial number: ***
If we're keeping score, this drive shows a manufactured date of July 2024, and I just got it last week from Amazon in the US. I have a physical win11 install ready to do the flashing. Thanks!
Revision: 1.02
Serial number: ***
PM sent.harfdorkinson wrote: Sat Jun 21, 2025 10:52 pm Hey @Coopervid, you sound like the most helpful of folks to make my fresh BDR-212V read UHD:
Revision: 1.02
Serial number: ***
calebhodge72
Hey @Coopervid - any chance I could get a PM as well?calebhodge72 wrote: Sat Jun 21, 2025 8:31 pm Hi @Coopervid,
Drive info:Also, if I get another BDR-212V in the future, will I be able to re-use the flasher you send? Or is it tied to a specific firmware date, bus encryption flag, or AACS version?Code: Select all
OS device name: F: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: [redacted] Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 81 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
PM sent.calebhodge72 wrote: Sun Jun 22, 2025 5:40 pmHey @Coopervid - any chance I could get a PM as well?calebhodge72 wrote: Sat Jun 21, 2025 8:31 pm Hi @Coopervid,
sweetnessbear23
@Coopervid,
Please PM the LibreDrive instructions.
Revision: 1.02
Thank You ahead of time!
-Sweetness
Revision: 1.02
-Sweetness
Last edited by sweetnessbear23 on Wed Jun 25, 2025 8:39 pm, edited 1 time in total.
AustinK
@Coopervid,
Please PM the LibreDrive instructions to get the pioneer 212v to read 4k.
Drive 1:
OS device name: F:
Revision: 1.02
Serial number:
Highest AACS version: 76
Drive 2:
OS device name: F:
Revision: 1.02
Serial number:
Drive3:
OS device name: F:
Revision: 1.02
Serial number:
Drive 1:
OS device name: F:
Revision: 1.02
Serial number:
Drive 2:
OS device name: F:
Revision: 1.02
Serial number:
Drive3:
OS device name: F:
Revision: 1.02
Serial number:
spamfaker
@Coopervid
I'm one of the panicbuyers of the 212v as well it seems. I'm using my drive to slowly make backups of all my DVDs and was about to get into the UHD section.
Wondering if I could be included in your ever growing PM cavalcade?
Revision: 1.02
Serial number:
Highest AACS version: 70
PM sent.spamfaker wrote: Mon Jun 23, 2025 2:30 am @Coopervid
Wondering if I could be included in your ever growing PM cavalcade?Code: Select all
Drive Information OS device name: \Device\CdRom1 Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 70 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
