BDR 212V UHD Guide
Re: BDR 212V UHD Guide
bill_w wrote: Thu Jun 19, 2025 2:30 am Is it possible to flash one of these on Linux?
No. You will need a good VM with Windows like VMWare.
bill_w
Post by bill_w »
What version of Windows is required? I have an old XP VM. Will that work?
bill_w wrote: Fri Jun 20, 2025 6:01 pm What version of Windows is required? I have an old XP VM. Will that work?
It should.
Coopervid wrote: Fri Jun 20, 2025 8:45 pm
It should. Windows 95 or NT 4.0 or higher.
Perdido wrote: Fri Jun 20, 2025 1:14 am Hi, like PlayMeAGroove I bought a bunch of Pioneer drives while I can, I might even get a few more later.
May I please have upgrades for these four drives:
Drive 1
Manufacturer: PIONEER
Product: BD-RW BDR-212D
Revision: 1.02
Serial number:
Firmware date: 2022-03-16
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8F00
Firmware version: 1.02/ID61
Drive 2
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: AEDL010899WL
Firmware date: 2020-07-21
Firmware version: 1.01/ID56
Drive 3
Revision: 1.00
Serial number:
Firmware date: 2019-01-10
Firmware version: 1.00/ID61
Drive 4
Revision: 1.01
Serial number:
Grateful for the terrific help!
PM sent.
Mikin wrote: Fri Jun 20, 2025 8:41 am Hello @Coopervid,
Could you please help me flash my BDR-212V to read UHD?
Here is my drive info:
OS device name: \Device\CdRom2
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-05-31
Highest AACS version: 77
Firmware version: ID06
Best Regards
PM sent.
calebhodge72
Post by calebhodge72 »
Hi @Coopervid,
Thanks for all the help you've provided to everyone here on the forums. You're a legend. Could I also get a PM for my BDR-212V to read UHD?
Drive info:
OS device name: F:
Revision: 1.02
Also, if I get another BDR-212V in the future, will I be able to re-use the flasher you send? Or is it tied to a specific firmware date, bus encryption flag, or AACS version?
harfdorkinson
Post by harfdorkinson »
Hey @Coopervid, you sound like the most helpful of folks to make my fresh BDR-212V read UHD:
Revision: 1.02
Serial number: ***
If we're keeping score, this drive shows a manufactured date of July 2024, and I just got it last week from Amazon in the US. I have a physical win11 install ready to do the flashing. Thanks!
harfdorkinson wrote: Sat Jun 21, 2025 10:52 pm Hey @Coopervid, you sound like the most helpful of folks to make my fresh BDR-212V read UHD:
Revision: 1.02
Serial number: ***
PM sent.
calebhodge72
calebhodge72 wrote: Sat Jun 21, 2025 8:31 pm Hi @Coopervid,
Drive info:
OS device name: F:
Revision: 1.02
Hey @Coopervid - any chance I could get a PM as well?
calebhodge72 wrote: Sun Jun 22, 2025 5:40 pm
Drive info:
OS device name: F:
Revision: 1.02
PM sent.
sweetnessbear23
Post by sweetnessbear23 »
@Coopervid,
Please PM the LibreDrive instructions.
Revision: 1.02
Thank You ahead of time!
-Sweetness
Last edited by sweetnessbear23 on Wed Jun 25, 2025 8:39 pm, edited 1 time in total.
AustinK
Post by AustinK »
@Coopervid,
Please PM the LibreDrive instructions to get the pioneer 212v to read 4k.
Drive 1:
OS device name: F:
Revision: 1.02
Serial number:
Highest AACS version: 76
Drive 2:
OS device name: F:
Revision: 1.02
Serial number:
Drive3:
OS device name: F:
Revision: 1.02
Serial number:
spamfaker
Post by spamfaker »
@Coopervid
I'm one of the panicbuyers of the 212v as well it seems. I'm using my drive to slowly make backups of all my DVDs and was about to get into the UHD section.
Revision: 1.02
Serial number:
Highest AACS version: 70
Wondering if I could be included in your ever growing PM cavalcade?
spamfaker wrote: Mon Jun 23, 2025 2:30 am @Coopervid
Revision: 1.02
Serial number:
PM sent.
