[Solved, thank you!] Decrypt AACS v82 disc
hed217
#1 Post by hed217 » Thu Jun 19, 2025 10:25 pm
Hi I am facing a problem decrypting an AACS v82 Blu-ray disc.
Here is the .tgz file.
Appreciate if someone can help to update in keydb.
Thanks in advance!
Re: Decrypt AACS v82 disc
#2 Post by MartyMcNuts » Fri Jun 20, 2025 3:12 am
Thanks in advance!
The latest KeyDB contains a record for this disc. Please download it and put it in your MakeMKV data directory (where the TGZ dumps are generated) and you should be able to rip it.
hed217
#3 Post by hed217 » Fri Jun 20, 2025 10:53 am
Successfully ripped the disc. Thank you so much :D
Dopefish
#4 Post by Dopefish » Fri Jun 20, 2025 4:44 pm
How does one do that?
NGr2023
#5 Post by NGr2023 » Fri Jun 20, 2025 5:55 pm
Download from http://fvonline-db.bplaced.net/
Dopefish
#6 Post by Dopefish » Fri Jun 20, 2025 6:31 pm
Tkx. I did that, let me rip the disc.
hbk4ever
#7 Post by hbk4ever » Sat Jun 21, 2025 2:03 pm
Thanks in advance!
Do I need to extract the keydb.cfg from the archive when I place it in my MakeMKV data directory?
#8 Post by MartyMcNuts » Sat Jun 21, 2025 11:32 pm
Thanks in advance!
Yes.
