Cannot write blu ray after decoding
When I upgraded from windows 7 to the latest version I found I couldn’t write to hard drive or disc. If I had known this would happen it would never have been done. Can you tell me the reason it was changed.
Re: Cannot write blu ray after decoding
Nah that's not a thing
What exactly are you trying to do?
The program still works ok but as soon it changes to playback there is a whole new section telling you why there is no matching soundtrack how you arrive at this point I have no idea.anyone have any clue as to what is happening.
You are providing only bits and pieces and therefore nobody will figure out the nature of your problem(s).
The very last page on MakeMKV is not the page it should be instead of the normal one there is a page stating there is no soundtrack available for the file. I’m sorry if this not clear but is what I’m seeing thanks
MakeMKV does not play videos. Are you trying to use Windows Media Player with a .mkv file? Windows Media Player won't play DTS audio tracks by default. You have a download a codec pack.
I seem to have got everyone confused which is not my purpose,anyhoo I must say now this not something I am comfortable with. After using makemkv to unscramble you are left with the file which you can send
into a file folder but at the moment when the file is written it tells me there is no sound on the file
I have recently changed from windows 10 to latest version of windows not sure if this has any bearing but would be grateful for any useful feedback
I have been using this,programme for years without any problems
Thank you in anticipation
Charlie
Charlie
Perhaps you can post a screen shot of what you're seeing?
We can't play the audio for THE LAST STARFIGHTER - 4K UHD.
Its encoded in 7 format which isn't supported. You can still watch the video.
Learn more about codecs | Send feedback
01:40:28
This is a copy of screen
Charlie
01:40:28
Charlie
try vlc
Well don’t I feel stupid it was hiding here all the time. Mind you I think is time to give this up as it’s all to complicated for me.Hopefully you won’t have to be bothered with me again.
No ones bothered
We like helping people with stuff we know about.
You have to learn somehow no need to be discouraged
