[Solved, thank you!] Decrypt AACS v82 disc
hed217
Post by hed217 »
Hi I am facing a problem decrypting an AACS v82 Blu-ray disc.
Here is the .tgz file.
Appreciate if someone can help to update in keydb.
Thanks in advance!
Re: Decrypt AACS v82 disc
hed217 wrote: Thu Jun 19, 2025 10:25 pm Hi I am facing a problem decrypting an AACS v82 Blu-ray disc.
Thanks in advance!
The latest KeyDB contains a record for this disc. Please download it and put it in your MakeMKV data directory (where the TGZ dumps are generated) and you should be able to rip it.
hed217
Post by hed217 »
Successfully ripped the disc. Thank you so much :D
Dopefish
Post by Dopefish »
MartyMcNuts wrote: Fri Jun 20, 2025 3:12 am The latest KeyDB contains a record for this disc. Please download it and put it in your MakeMKV data directory (where the TGZ dumps are generated) and you should be able to rip it.
How does one do that?
NGr2023
Post by NGr2023 »
Dopefish wrote: Fri Jun 20, 2025 4:44 pm How does one do that?
Download from http://fvonline-db.bplaced.net/
Dopefish
Post by Dopefish »
NGr2023 wrote: Fri Jun 20, 2025 5:55 pm
Tkx. I did that, let me rip the disc.
hbk4ever
Post by hbk4ever »
Thanks in advance!
Do I need to extract the keydb.cfg from the archive when I place it in my MakeMKV data directory?
hbk4ever wrote: Sat Jun 21, 2025 2:03 pm
Thanks in advance!
Yes.
