Ultimate UHD Drives Flashing Guide Updated 2025
Sam88
Post by Sam88 »
Coopervid wrote:
Tue Jun 10, 2025 9:39 pm
Sam88 wrote:
Tue Jun 10, 2025 7:00 pm
I just purchased a Verbatim 43888, because it was frequently suggested.
Can you tell me if it is flashable and which Firmware to use?
OS device name: E:
Product: BDDVDRW GGC-H20L
Revision: 1.02
Serial number: ...
Firmware date: 2007-12-27 12:34:56
Highest AACS version: 77
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.02-
Not possible.
I am sorry, I had the wrong drive selected.
That's why I couldn't find the right firmware in the instructions.
This is the right one now:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: XXXXXXXXXXXX
When following the first post it should be possible with this firmware, right?
BU40N on any Firmware directly to > BU40N 1.03MK
Correct.
TripleHalt
Post by TripleHalt »
Hello, I'm something of an idiot and if it's at all possible I was wondering if someone could give me like a 123 "do this" tutorial for flashing my drive? I bought an ASUS BW-16D1HT and I understand the basic steps, but I really don't want to accidentally brick this thing. Sorry if this is egregious, I'm new to this whole endeavor.
TripleHalt wrote:
Sun Jun 22, 2025 9:04 am
You can email me for a flash kit see below
crow.
Post by crow. »
Good afternoon,
I bought a BP50NB40 running version 1.00, see screenshot https://i.imgur.com/gcF4EhM.png. I was told that this should be able to rip 4Ks without the need for flashing. However, when i insert a 4k, MakeMKV doesn't recognize the disc and simply states that there are no disc. Does that mean I have to flash the firmware to make it work?
If so, could you direct me to all the firmwares needed to make this run.
Appreciate all your help in advance.
~crow
crow. wrote:
Mon Jun 23, 2025 12:02 am
Good afternoon,
~crow
Sorry that drive is to old don't flash it
Mr_Orange
Post by Mr_Orange »
Billycar11 wrote:
Mon Jun 23, 2025 7:31 pm
Good afternoon,
~crow
Why? It is platform MT1959 and appears on the list of flashable drives in post #1. I'm asking for eductional purposes.
crow.
Post by crow. »
Good afternoon,
~crow
Also curious since it's listed in the post and is the reason i bought it. Does that mean I cannot burn 4K with the drive?
Thanks for your help
~crow
Your drive can't read UHDs and it is low quality to burn discs. Either skip burning or get a Pioneer. Even then burns will be bad since media has gone south.
Mr_Orange wrote:
Mon Jun 23, 2025 9:52 pm
Good afternoon,
~crow
But it's from before 2016 it will die if he flashes it trust me
It's still an nb40 drive not nb50/52
asmcom
Post by asmcom »
Billycar11 wrote:
Tue Jun 24, 2025 12:02 am
Many customers have made this mistake. Do not flash or it is time to get out your dos tools.
Asmcom
crow.
Post by crow. »
That’s disappointing to hear since I thought I scored a drive for cheap. Appreciate everyone’s input.
~crow
robrienii
Post by robrienii »
I keep getting an error code 0x82052603 is there any help?
robrienii wrote:
Fri Jun 27, 2025 5:17 pm
As a first: Post your Makemkv info. Make sure your drive is empty and closed when you are trying to flash.
jrips
Post by jrips »
Hi guys,
I bought a Pioneer BDR-XS07TUHD risking that it would be revision 1.03 which it is. Is it possible to get into a libredrive mode or not?
Product: BD-RW BDR
Revision: 1.03
Firmware date 2023-01-06
Firmware version: ID05
