All Pioneer drives will be LibreDrive supported
Re: All Pioneer drives will be LibreDrive supported
Post by Coopervid » Fri Jun 13, 2025 10:09 pm
Packers948 wrote: Fri Jun 13, 2025 10:02 pm
Billycar11 wrote: Fri Jun 13, 2025 7:18 am
flojo wrote: Thu Jun 12, 2025 3:13 pm Lithium based products have taken over these applications almost entirely.
from the factory pioneer uses clear lube likely silicone lithium grease is usually white
So we mostly do not need to grease anything inside these drives right - Thanks
Np. Compared to applications for automotive etc. these drives only work far less hours.
Post by SamuriHL » Fri Jun 13, 2025 11:47 pm
I finally got around to cross-flashing the new 212v drive I got off Amazon. Given that Pioneer has gotten out of the drive business, maybe it's time to discuss the unique properties of these older 212 based drives being cross-flashed to 212ubk (and probably 512 firmware, as well I'd wager). They work perfectly as LibreDrives for UHD. Awesome little drives. We already know this. However, one of the neat properties is that they "forget" how to bus encrypt discs all on their own. No LibreDrive required for such magic. This allows you to make ISO images directly off the disc without having to do anything else. Works for Blu-ray and UHD. :D
Post by Billycar11 » Sat Jun 14, 2025 1:19 am
Packers948 wrote: Fri Jun 13, 2025 10:02 pm So we mostly do not need to grease anything inside these drives right - Thanks
Correct it would be many years before it's needed
bird333
Post by bird333 » Sun Jun 15, 2025 1:11 pm
SamuriHL wrote: Fri Jun 13, 2025 11:47 pm I finally got around to cross-flashing the new 212v drive I got off Amazon. Given that Pioneer has gotten out of the drive business, maybe it's time to discuss the unique properties of these older 212 based drives being cross-flashed to 212ubk (and probably 512 firmware, as well I'd wager). They work perfectly as LibreDrives for UHD. Awesome little drives. We already know this. However, one of the neat properties is that they "forget" how to bus encrypt discs all on their own. No LibreDrive required for such magic. This allows you to make ISO images directly off the disc without having to do anything else. Works for Blu-ray and UHD. :D
Can you explain how one does this? What software is used, etc?
Post by SamuriHL » Sun Jun 15, 2025 1:16 pm
bird333 wrote: Sun Jun 15, 2025 1:11 pm
SamuriHL wrote: Fri Jun 13, 2025 11:47 pm This allows you to make ISO images directly off the disc without having to do anything else. Works for Blu-ray and UHD. :D
Use whatever software you want if you have one of these cross-flashed drives. I use ImgBurn for the purpose a lot of times. The point is that if you have one of these fun drives, there's no bus encryption to worry about so you can use whatever you want to created a protected ISO. Remember, it makes a PROTECTED image which still has to be decrypted.
VA1DER
Post by VA1DER » Tue Jun 24, 2025 5:01 pm
SamuriHL wrote: Sun Jun 15, 2025 1:16 pm
bird333 wrote: Sun Jun 15, 2025 1:11 pm Can you explain how one does this? What software is used, etc?
I think he meant what software do you use to cross flash it.
Post by Coopervid » Tue Jun 24, 2025 5:28 pm
VA1DER wrote: Tue Jun 24, 2025 5:01 pm
Nah. He's good and I helped him to flash his drive.
Post by SamuriHL » Tue Jun 24, 2025 11:37 pm
They were very specific in what they quoted.
Mr. Red
Post by Mr. Red » Wed Jun 25, 2025 3:07 pm
Viktor wrote: Fri Jun 13, 2025 8:36 pm Hi all, new to Ripping and it's more so a question of the hardware and this is my first post here. Pls bear in mind that I'm currently located in Germany and will be using the drive with my M2 MBP.
Being where I am there was little choice of what external optical drive is available to be purchased and it was really only this Verbatim #43888 model (an older model) via Amazon.de that could be purchased.
Through this websites I learned that it came with either an LG or Pioneer drive inside the Verbatim housing. The drive arrived and it's an LG, came with native region code 1 (the US) and that it was likely destined for the US as the EU market likely predominately shipped with a Pioneer. I did read somewhere that folks from the US have used Amazon Germany to order, to ensure they received the Pioneer.
I could send it back and hope for the best to get the Pioneer in the Amazon sweep stakes.
To those in the know, the Pioneer is meant to be a LibreDrive, making it easier to use out of the box for ripping? I spoke to Verbatim EU today and they also put forward that Pioneer hasn't updated the Firmware for quite some time and back in 2022/2023 an update killed many capabilities. Tech support also mention they rather get more complaints for ripping with the Pioneer due to the Firmware update. Also I sporadically read a mention of on the make MKV forum. I did find a site with instructions of flashing Libre Firmware onto the LG I have.
As you can tell I'm a newcomer to this and still in a return window. To those familiar with this model and choice of internals, please weigh in if the Pioneer or the LG (I have) is the better option to go for and sorry this post got lengthy.
Since Pioneer stopped the production of BD drives, it's very unlikely that you will find a Pioneer drive in a new Verbatim 43888. Maybe on a shop that doesn't sell much of them and has old stock.
If it has to be a Pioneer, asmcom delivers into the EU: viewtopic.php?f=20&t=19387
Or you flash the LG BU40N to make it LibreDrive compatible: viewtopic.php?f=16&t=19634
Region code shouldn't matter for ripping, but can be changed a few times if you also want to use the drive for normal media playback.
CalicoSkies
Post by CalicoSkies » Fri Jun 27, 2025 1:34 am
My spare Pioneer BDR-212V drive is flashed and stored away now! I have one in my PC already (which I bought in October), and recently I bought another from Amazon as a spare. I just plugged it in and flashed it with the LibreDrive firmware and packed it back up in the box, so it's ready to be used when needed.
I think this has been a great drive so far. I'd recommend getting one while they're still available:
Amazon link: https://www.amazon.com/dp/B08R89FN61
After flashing, it appears as a BDR-S12U 1.02 and firmware name "PIONEER BDR-212T":
BrianDW
Post by BrianDW » Sat Jun 28, 2025 11:38 pm
So, like, when?
Post by MartyMcNuts » Sun Jun 29, 2025 12:26 am
BrianDW wrote: Sat Jun 28, 2025 11:38 pm So, like, when?
No ETA. Just sometime in the future.
VA1DER
Post by VA1DER » Sun Jun 29, 2025 4:58 pm
MartyMcNuts wrote: Sun Jun 29, 2025 12:26 am
Fair enough, but if anyone has an idea on what scale of "future" we're thinking about, it would be helpful. Days, weeks, months, years. I don't think anyone is looking for promises, but it would help with purchasing decisions for a lot of folks. If anyone knows.
Post by SamuriHL » Sun Jun 29, 2025 5:01 pm
It's 100% irrelevant for "purchasing decisions". Pioneer drives are going to be all but gone soon. So buy one now or forever hold your regret. Mike hasn't given ANY timeline so any speculation will not be useful.
VA1DER
Post by VA1DER » Sun Jun 29, 2025 8:45 pm
SamuriHL wrote: Sun Jun 29, 2025 5:01 pmIt's 100%
...relevant for people considering paying a lot extra for the even rarer pre-2022-firmware Pioneer drives. If it's going to be on the order of months, then people may want to buy or (stick with already purchased) post-2022 firmware drives and wait for the "fix". If it's going to be on the order of a year or more, people may want to fork out now for the pre-2022 drives while they are still (somewhat) available and pay that premium. So the information is more relevant now than it ever will be.
SamuriHL wrote: Sun Jun 29, 2025 5:01 pm ...so any speculation will not be useful...
As you may read in my last, I'm not asking anyone to speculate. But there may be people involved in this who, while they may not be able to commit to a specific timeline, at least know the order of magnitude involved. Or Mike may be reading this. So, if anyone has anything to add, it would be useful, appreciated, and timely to share now. And if not, there was certainly no harm in asking.
