Is the Pioneer BDR209-EBK Flashable for UHD compatibility?
Deeply_Cynical
The Blue laser in my WH14NS40 has just expired, I have an old Pioneer BDR-209EBK (Shows as a 209M in MakeMKV) lying around.
Is this flashable to be UHD compatible?
I'm assuming yes as every thread I've read on here as a "PM Sent" reply followed by a "Thanks that worked" from the OP.
Drive info:
OS device name: /dev/sr2
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.30
Serial number: OED#######WL
Firmware date: 2014-12-05
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8600
Firmware version: 1.30/ID60
Thanks in advance.
Drive info:
Revision: 1.30
Thanks in advance.
Re: Is the Pioneer BDR209-EBK Flashable for UHD compatibility?
you can pm cooper or email me below
Deeply_Cynical
Drive is now compatible thanks to Billy, You absolute legend.
Same here, my device is not working.
OS device name: Y:
Revision: 1.20
Serial number:
Firmware date: 2014-04-08
Firmware version: 1.20/ID60
OS device name: Y:
Revision: 1.20
Serial number:
See belowqwer_0 wrote: Sun Jan 05, 2025 12:27 pm Same here, my device is not working.
OS device name: Y:
Revision: 1.20
Serial number:
DerGuteThor
hello,
i have have the exact same Pioneer Drive. i bought this drive becuase my Asus drive just dont rip some of my UHD discs. so in the Makemkv software the pioneer shows as "enabled" but it wont read any UHD-Discs, unlike for the asus i cant find any info about what Firmware i need for the pioneer in order to make it read UHD-discs.
thanks in advance for any Help
thor
thor
Post your Makemkv info.DerGuteThor wrote: Fri May 23, 2025 9:36 am hello,
thor
DerGuteThor
Revision: 1.51
Serial number: RIDL006765WL
Firmware date: 2018-05-08
Drive platform: RS8601
Firmware version: 1.51/ID60
Revision: 1.51
Thanks. You don't have the exact same Pioneer drive and therefore I needed the Makemkv info. PM sent.DerGuteThor wrote: Sat May 24, 2025 7:22 am Drive Information
Revision: 1.51
DerGuteThor
Thnak you very much, that worked!
Toscaclarinet
I have also bought a 209EBK as a spare and would like to be able to read UHD discs, if it's not too much trouble.
OS device name: \Device\CdRom2
Revision: 1.20
Serial number: *****
Revision: 1.20
PM sent.Toscaclarinet wrote: Thu Jun 12, 2025 11:12 pm I have also bought a 209EBK as a spare and would like to be able to read UHD discs, if it's not too much trouble.
Revision: 1.20
Toscaclarinet
Thanks Coopervid, that worked. Even these older Pioneer drives seem to read problematic discs better than the BU40N.
Is this something that will work with my BDR-209D as well? Thanks!
email me your drive info sectionRicoSuave wrote: Tue Jun 24, 2025 1:48 am Is this something that will work with my BDR-209D as well? Thanks!
