Changing mkv track header info result - unplayable
setarip_old
Re: Changing mkv track header info result - unplayable
Post by setarip_old »
Hi!
I don't know if the following is relevant but, I seem to recall that a while back (perhaps several months ago), there was a big brouhaha resulting from "MKVMerge/Toolnix" changing its output from a "full" header" to a "compressed" header that was other than fully compatible with "MKVMerge/Toolnix" files created with "full" headers.
I wonder if this could have anything to do with what you're experiencing...
Chetwood
Post by Chetwood »
Doubtful. Mosu will make sure that newer versions of MKVToolnix can read all previously authored MKVs.
setarip_old
@Chetwood
Hi!
I believe you'll find posts referring to this situation in "Mosu's" thread at the Doom9 Forums...
Chetwood
Post by Chetwood »
URL or it didn't happen ;)
DiscoVision
Post by DiscoVision »
I'm going to resurrect this thread. I have found I can change the name of the audio channels without any problem. However, if I add the 'Commentary Track' element (flag) to ANY track, the resultant MKV file will not play in anything other than VLC. IMO, VLC isn't the end-all player. If none of the built in windows players (including windows explorer) recognize the file as valid.
I have just 'restored' a file which I had flagged 4 separate tracks with the "Commentary Track" flag by simply removing the element. But I had to remove it from all 4 tracks before the file will work in Windows and Plex.
DiscoVision wrote: Thu Jun 12, 2025 9:37 pm I'm going to resurrect this thread. I have found I can change the name of the audio channels without any problem. However, if I add the 'Commentary Track' element (flag) to ANY track, the resultant MKV file will not play in anything other than VLC. IMO, VLC isn't the end-all player. If none of the built in windows players (including windows explorer) recognize the file as valid.
The Commentary Flag is a Matroska v4 element. It could be the case that some players don't know how to correctly parse a v4 file.
