ASUS SBW-06D2X-U
zittrig
Re: ASUS SBW-06D2X-U
Post by zittrig » Thu Jun 05, 2025 5:14 pm
Coopervid wrote: Thu Jun 05, 2025 6:06 am
zittrig wrote: Thu Jun 05, 2025 5:56 am Thanks for your reply :!:
Lenses are cleaned with alcohol, of course. What is good for me will be also good for the lenses ....
Power comes with an USB-Y-Power cable. That shouldn't be the problem, I think. But I'll ask another friend for his powered hub.
The hint with testing the drive by burning a BD will be tested after work. I will report then.
You are very welcome! The lens will most likely appreciate a higher content percentage on alcohol as you do :D :D .
I'm afraid you're right :D :D
Ok, the burning test with 23 GB data to a BD-R was not successfull. Burning with Windows Explorer broke up with an error about the writing speed, it doesn't matter which speed I'd choose. A try with the ImgBurn Tool brokes up with a power calibration error. But the drive gets enough power. Also a hint to a nearly defective laser?
larsd
Post by larsd » Tue Jun 10, 2025 11:59 am
I have this drive, too:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Firmware Date: 2017-04-18
LibreDrive Information: Status: Possible, not yet enabled
Firmware version: ID22
could you please help me?
Post by Coopervid » Tue Jun 10, 2025 4:11 pm
larsd wrote: Tue Jun 10, 2025 11:59 am I have this drive, too:
Manufacturer: ASUS
Revision: 1.10
PM sent.
An1on
Post by An1on » Thu Jun 12, 2025 6:59 pm
Good evening everyone,
I have an ASUS SBW-06D2X-U drive that I would like to make UHD-compatible.
Is this possible with my specific device?
Many thanks and best regards,
Anton
Manufacturer: ASUS
Revision: 1.03
Serial number: Q**********L
Firmware date: 2016-12-16
Drive platform: RS8510
Firmware version: 1.03/ID22
Post by Coopervid » Thu Jun 12, 2025 7:33 pm
An1on wrote: Thu Jun 12, 2025 6:59 pm Good evening everyone,
Anton
Manufacturer: ASUS
Revision: 1.03
PM sent.
HUGbsd
Post by HUGbsd » Fri Jun 13, 2025 7:10 am
I am very new to the topic and read a lot of forum posts in the last few days. It seems like my drive needs to be flashed to be able to enable LibreDrive. Here are the details of my drive:
Drive Information:
Manufacturer: ASUS
Revision: 1.11
Serial number: D**********L
Firmware date: 2023-04-20
Is it possible to enable LibreDrive with my drive as suggested in the output? Is it possible to adjust the firmware to be UHD compatible? Is it true that I need a Windows PC to flash the drive?
I am thankful for any help on the topic!
Post by MartyMcNuts » Sat Jun 14, 2025 12:55 am
HUGbsd wrote: Fri Jun 13, 2025 7:10 am Hello,
Drive Information:
Manufacturer: ASUS
Revision: 1.11
Your drive cannot currently be flashed as the firmware on it is too new. Must be pre December 2022. Apparently, drives with newer firmware will eventually be supported, sometime in the future.
spinal_cord
Post by spinal_cord » Fri Jun 27, 2025 8:19 pm
Hi, I recently got an ASUS SBW-06D2X-U, and noticed that although it is advertised as a 6x drive, it only rips with makemkv at 1.9x to 2.0x.
Is this usual?
Also, I have been reading that flashing the drive with different firmware to be able to read 4k disks might be possible, would this also help with the read speed? I have the following info from makemkv...
Manufacturer: ASUS
Revision: 1.10
Serial number: XXXX000000XX
Firmware date: 2017-04-18
Highest AACS version: 68
Thanks in advance :-)
Kimsor
Post by Kimsor » Sat Jun 28, 2025 11:32 am
Hi.
my drive info:
OS device name: F:
Current profile: BD-R SRM
Manufacturer: ASUS
Revision: 1.10
Serial number:
Highest AACS version: 46
i would like to make it uhd combatible. thanks!
Post by Coopervid » Sat Jun 28, 2025 6:25 pm
spinal_cord wrote: Fri Jun 27, 2025 8:19 pm Hi, I recently got an ASUS SBW-06D2X-U, and noticed that although it is advertised as a 6x drive, it only rips with makemkv at 1.9x to 2.0x.
Is this usual?
Manufacturer: ASUS
Revision: 1.10
PM sent.
Post by Coopervid » Sat Jun 28, 2025 6:27 pm
Kimsor wrote: Sat Jun 28, 2025 11:32 am Hi.
my drive info:
OS device name: F:
Manufacturer: ASUS
Revision: 1.10
Serial number:
PM sent.
drwh65
Post by drwh65 » Wed Jul 02, 2025 9:33 am
Hi, I have the following drive:
Manufacturer: ASUS
Revision: 1.10
Serial number:
Highest AACS version: 81
I'd be grateful for any help to enable libredrive. Many thanks!
Post by Coopervid » Wed Jul 02, 2025 8:08 pm
drwh65 wrote: Wed Jul 02, 2025 9:33 am Hi, I have the following drive:
Manufacturer: ASUS
Revision: 1.10
Serial number:
Pm sent.
Yota13
Post by Yota13 » Tue Jul 08, 2025 9:10 am
Hi !
Here is the information about my drive. Would it be possible to get it LibreDrive'd ? :-) Thank you so much !
Informations lecteur
Nom du lecteur SE : F:
Fabricant : ASUS
Produit : SBW-06D2X-U
Révision : 1.11
Numéro de série : DADL287315WL
Date micrologiciel : 2023-04-20
Marqueurs d'encryptage bus : 1B
Post by Coopervid » Tue Jul 08, 2025 11:34 am
Yota13 wrote: Tue Jul 08, 2025 9:10 am Hi !
Fabricant : ASUS
Révision : 1.11
No. Your firmware is too new. You have to wait until Mike comes up with a solution for your drive.
