Since opening my several selfripped DVD-ISO files
with new 1.7.0 Makemkv always crashes
directly after analysing titles and the final
"Operation successfully completed"-message.
Popup: "Fatal error occurred, program will now exit."
Debug log shows NO further info WHY it crashes.
Last log entry is always "Operation successfully completed"...and nothing more.
Every single of my .ISO files I tested can be used successfully
with the older 1.6.16 and downwards without any problems.
Therefore - I guess - it cannot be a problem of the ISO-files.
Only 1.7.0 crashes. The effect is reproducible on all my PCs.
Very strange.
Running Win7x64SP1, fully patched.....using Makemkv with Direct Disc Access
but same effect also with files from VIDEO_TS Dir's
						1.7.0 Crash after "Operation successfully completed" on ISOs
				Grendelbox
- Contact:
Re: 1.7.0 Crash after "Operation successfully completed" on
Please continue discussion in http://www.makemkv.com/forum2/viewtopic.php?f=1&t=4392
