Do I need to flash my BDR-XD05
buyitownit
Post by buyitownit »
Hi! I'm new to this as I recently decided to cancel crappy Netflix and build a real media collection. I've got around 100 DVD/Blu-ray discs and would like to use MakeMKV to put them on my Plex server.
I've found an old Pioneer BDR-XD05 and am hoping I can use it to rip my collection. Here the stats from MakeMKV:
Manufacturer: PIONEER
Product: BD-RW BDR-XD05
Revision: 1.21
Serial number: ...
Firmware date: 2014-04-02
Highest AACS version: 65
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 1.21
I've read a lot about flashing firmware, do I need to flash this drive? Can someone hold my hand and help?
Re: Do I need to flash my BDR-XD05
buyitownit wrote: Wed Jun 11, 2025 5:05 pm Hi! I'm new to this as I recently decided to cancel crappy Netflix and build a real media collection. I've got around 100 DVD/Blu-ray discs and would like to use MakeMKV to put them on my Plex server.
Revision: 1.21
Serial number: ...
It will work for DVD and BD anyway. If you intend to rip UHDs just reply to this and we can make it happen.
buyitownit
Yes, having UHD capability would be ace!
buyitownit wrote: Wed Jun 11, 2025 6:02 pm Yes, having UHD capability would be ace!
PM sent.
buyitownit
Amazing! Thank you.
Does this look correct?
Product: BD-RW BDR-XD06U
Revision: 1.11
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 66
Drive platform: RS8B30
Firmware name: PIONEER BDR-XS06
Firmware version: 1.11/ID69
buyitownit wrote: Wed Jun 11, 2025 7:54 pm Amazing! Thank you.
Revision: 1.11
Serial number:
Put an UHD in your drive and you will start smiling...
buyitownit
Great! I will find a UHD and give it a try!
labe225
Post by labe225 »
I was wondering if I could also get some assistance?
OS device name: E:
Revision: 3.01
Serial number:
Firmware date: 2014-12-26
Highest AACS version: 76
Firmware version: 3.01/ID34
labe225 wrote: Fri Aug 29, 2025 1:01 am I was wondering if I could also get some assistance?
OS device name: E:
Revision: 3.01
Serial number:
PM sent.
labe225
Post by labe225 »
Coopervid wrote: Fri Aug 29, 2025 10:35 am
OS device name: E:
Revision: 3.01
Serial number:
PM sent.
Thanks, everything worked flawlessly!
Monyx
Post by Monyx »
Can firmware be flashed for UHD read?
Revision: 3.10
Serial number:
Drive platform: RS8232
Firmware version: 3.10/ID34
Monyx wrote: Sat Aug 30, 2025 1:00 am Can firmware be flashed for UHD read?
Revision: 3.10
Serial number:
yes email me that drive info section see below for email
g4x86matrix
Post by g4x86matrix »
I bought my Pioneer BD-RW BDR-XD05 six years ago, but after upgrading its official firmware once, its access to UHD was disabled. Can I get some assistance to re-enable its UHD functions?
The drive info is the following:
OS device name: /dev/sr0
Current profile: DVD-ROM
Revision: 3.10
Serial number:
Thanks a lot for any help!
g4x86matrix wrote: Sat Aug 30, 2025 2:14 pm I bought my Pioneer BD-RW BDR-XD05 six years ago, but after upgrading its official firmware once, its access to UHD was disabled. Can I get some assistance to re-enable its UHD functions?
Revision: 3.10
Serial number:
PM sent.
vidster
Post by vidster »
I have this drive and it has served me well for years with blu ray rips. Am I reading the posts correctly in that it is possible to to handle UHD?
Here is my drive info:
OS device name: E:
Revision: 3.01
Serial number:
Highest AACS version: 68
