Has anyone been able to test MacOS 15.5 yet?
Konten
Post by Konten » Tue May 13, 2025 6:18 am
Before installing just wanted to find out whether there are any issues with MakeMKV...
Thanks, guys!!
Mkvdsch
Re: Has anyone been able to test MacOS 15.5 yet?
Post by Mkvdsch » Thu May 22, 2025 3:51 am
No issues so far for me since updating to Mac OS 15.5 on the MacBook Air M1. Although I can only speak considering normal BD not 4K.
Konten
Post by Konten » Sun Jun 01, 2025 9:51 am
Brilliant, thanks!!
wstarkweather
Post by wstarkweather » Wed Jun 11, 2025 1:52 pm
Mine won't work, worked fine on previous version of 15, but 15.5 it will not work. I disabled gatekeeper, and tried the code from Mike in terminal and I get a fatal error message.
seamus
Post by seamus » Wed Jun 25, 2025 8:08 am
I successfully installed MakeMKV ver 1.18.1 on a macOS 15.5 just a few days ago. It was an iMac with an Intel processor - not the ARM processor.
TeKno Ziz
Post by TeKno Ziz » Wed Jul 02, 2025 4:07 pm
I installed and ran it yesterday, ripped a Blu-ray disk, apparently failed. Today I ran the app and MacOS said it wouldn't run it because it could verify whether it had malware.
Update: ran the terminal command to remove Gatekeeper and it worked fine.
danielsmith
Post by danielsmith » Tue Jul 22, 2025 8:04 am
I haven't tested MacOS 15.5 yet, but I'm curious to see how it performs with MakeMKV as well. I had a smooth experience with the previous version, so I'm hoping for the same this time. If anyone has tried it, please share your insights!
runezen
Post by runezen » Fri Aug 01, 2025 7:23 pm
Purchased license but no emails yet with the actual key. Anyone? Used the beta version for many years and thought I'd support the development.
Think twice before purchasing a permanent license because chances are you might never receive the mail with the actual KEY.
runezen
Post by runezen » Fri Aug 01, 2025 7:35 pm
"Your version it too old" is all I'm getting. And yes, I've tried re-downloading, re-installing etc. Also paid for a permanent key here but haven' received a confirmation email with the KEY.
karolchilinski
Post by karolchilinski » Sat Aug 02, 2025 12:35 am
It also says it for me also. Let's notify them.
karolchilinski
Post by karolchilinski » Sat Aug 02, 2025 12:39 am
Change your Macs date.
