zaybdr
Post by zaybdr » Wed Jun 11, 2025 10:11 am
Would you be able to help me too? I also have a similar drive. Details below:
Would the below be able to be flashed to do UHD
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.50
Serial number: RGDL025205WL
Firmware date: 2017-12-21
Highest AACS version: 76
Drive platform: Pioneer RS8601
Firmware version: GENE
Post by Coopervid » Wed Jun 11, 2025 12:17 pm
zaybdr wrote: Wed Jun 11, 2025 10:11 am Would you be able to help me too? I also have a similar drive. Details below:
Revision: 1.50
PM sent.
zaybdr
Post by zaybdr » Thu Jun 12, 2025 10:57 am
Coopervid wrote: Wed Jun 11, 2025 12:17 pm PM sent.
Thank you. I was able to get the UHD disc to be recognised.
slimman
Post by slimman » Fri Jun 13, 2025 4:05 am
Product: BD-RW BDR-208D
Revision: 1.10
Serial number:
Firmware date: 2012-08-22
Bus encryption flags: 13
Highest AACS version: 56
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
Is it possible to make it a UHD drive? Many thanks
zittrig
Post by zittrig » Fri Jun 13, 2025 10:58 am
I've a curious handling with a CH12NS40.
It had the original fw 1.00 installed which was 4k friendly and worked with MakeMKV.
But that drive I normaly flash to WH16NS60 1.02MK. But with the WH16NS60 1.02MK no 4K disc will be recognized in Windows (before opening MakeMKV). Trying, trying, trying, stop trying itself. CD/DVD no problem, normal BD ....... not tested. Just occurs to me :roll:
With the CH12NS40 1.03MK the drive recognize 4K discs but get very warm and breaks up ripping of 3-layer disc after about 75%.
With fw BC-12D2HT 3.11MK is all fine. Multiple tested.
Doesn't make sense to me....
Schachma
Post by Schachma » Fri Jun 13, 2025 11:28 am
I was able to acquire a similar drive to the ones previously mentioned and also wanted to see if it can be flashed for UHD and if someone would be able to help, it already says LibreDrive enabled. Thank you in advance!
Current profile: CD-ROM
Product: BD-RW BDR-209D
Revision: 1.50
Serial number:
Drive platform: RS8601
Firmware version: 1.50/ID61
Post by Coopervid » Fri Jun 13, 2025 11:38 am
zittrig wrote: Fri Jun 13, 2025 10:58 am I've a curious handling with a CH12NS40.
Well, I guess this is a combo, not a BD-writer. Maybe therefore it only likes combo firmware. And LG drives are not good readers concerning 3-layer discs.
zittrig
Post by zittrig » Fri Jun 13, 2025 11:50 am
Yes, it's a combo, like the ASUS BC-12D2HT / BC-12B1ST also. But this combo is the first which has problems with the WH16NS60 1.02MK, I had four or fives of CH12NS40 in the past. An with the fw of the BC-12D2HT it has no problems with the same 3-layer discs.
Could it be, that the blue laser is dying (again :mrgreen: ) and the fw WH16NS60 1.02MK needs more power than other firmware?
Post by Coopervid » Fri Jun 13, 2025 12:01 pm
zittrig wrote: Fri Jun 13, 2025 11:50 am Yes, it's a combo, like the ASUS BC-12D2HT / BC-12B1ST also. But this combo is the first which has problems with the WH16NS60 1.02MK, I had four or fives of CH12NS40 in the past. An with the fw of the BC-12D2HT it has no problems with the same 3-layer discs.
Did you clean the laser lens? A dying laser is a possibility. Since the other drives worked with the WH16NS60 firmware I don't think It's a power related issue that is caused by the firmware.
zittrig
Post by zittrig » Fri Jun 13, 2025 12:06 pm
Yes lenses are cleaned (with alcohol) several times.
OK, then I'll write it off as a curiosity. :mrgreen: Happy with a working drive.
Thank you.
slimman
Post by slimman » Fri Jun 13, 2025 2:16 pm
Hi, I have this blu ray drive. Is it possible to make it a UHD drive
Revision: 1.10
Serial number:
Thanks a lot!
tyme2tb
Post by tyme2tb » Sat Jun 14, 2025 1:20 am
Coopervid wrote: Wed Jun 11, 2025 7:05 am It will make your 209 a S11 / 211.
Thank you it works perfect, and I can now rip UHD disks
therobin
Post by therobin » Sat Jun 14, 2025 1:59 am
Hi, I just got in a BU40N. I just want to make sure I am have the right command to flash this drive correctly.
OS device name: /dev/sr0
Product: BD-RE BU40N
Revision: FR07
Serial number:
Firmware date: 2118-01-22 15:36
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.FR07J
I assume encryption flag line means this is encrpted firmware. According to the guide, I believe the following is the correct command line to flash directly to 1.03MK (firmware from the all you need zip) under linux:
makemkvcon f -d /dev/sr0 -f sdf.bin rawflash enc -i HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Am I good to proceed?
Sam88
Post by Sam88 » Sat Jun 14, 2025 11:17 am
Coopervid wrote: Tue Jun 10, 2025 9:39 pm
Sam88 wrote: Tue Jun 10, 2025 7:00 pm Hello,
I just purchased a Verbatim 43888, because it was frequently suggested.
Can you tell me if it is flashable and which Firmware to use?
OS device name: E:
Product: BDDVDRW GGC-H20L
Revision: 1.02
Serial number: ...
Firmware date: 2007-12-27 12:34:56
Highest AACS version: 77
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.02-
Not possible.
I am sorry, I had the wrong drive selected.
That's why I couldn't find the right firmware in the instructions.
This is the right one now:
OS device name: F:
Revision: 1.05
Serial number: XXXXXXXXXXXX
When following the first post it should be possible with this firmware, right?
BU40N on any Firmware directly to > BU40N 1.03MK
Post by Coopervid » Sat Jun 14, 2025 7:13 pm
Correct.
