Did you try an UHD? It should work with your drive as is. If not post again.Packers948 wrote: Tue Jun 03, 2025 1:28 am Hello,
Please let me know if this Pioneer – BDR-211UBK would be able to flash for UHD enable. Thank you so much for your help.
MakeMkv information as below.
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-211M
Revision: 1.02
Serial number: NA
Firmware date: 2017-02-23
Bus encryption flags: 13
Highest AACS version: 81
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.02/ID60
LibreDrive for Pioneer drives
Packers948
Hi - Thank you for the information - I am going to rip some 4k and Blu Ray disc today - Thanks again
Packers948
Hi - Thank you for the information - I am going to rip some 4k and Blu Ray disc today - Thanks againCoopervid wrote: Tue Jun 03, 2025 1:52 amDid you try an UHD? It should work with your drive as is. If not post again.Packers948 wrote: Tue Jun 03, 2025 1:28 am Hello,
OS device name: G:
Revision: 1.02
Serial number: NA
warpgremlin
Have Pioneer drive (SATA native, via USB enclosure to a Windows box).
UHD disks won't decrypt. Need firmware update... I think.
Product: BD-RW BDR-S13JX
Revision: 1.04
Serial number: xxxxxxxxxxxx
Firmware date: 2022-12-12
Highest AACS version: 61
Firmware version: ID72-
Not possible currently as your firmware is too new. You have to wait for a solution mike is working on.warpgremlin wrote: Sat Jun 07, 2025 7:27 pm Have Pioneer drive (SATA native, via USB enclosure to a Windows box).
Drive Information OS device name: D: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDR-S13JX Revision: 1.04 Serial number: xxxxxxxxxxxx Firmware date: 2022-12-12 Bus encryption flags: 1B Highest AACS version: 61 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9201 Firmware version: ID72
Arska
Hello.
I am sorry to be asking as I am sure that somewhere here there is a reply already.
I've read some conflicting information about whether my drive can or cannot be made to support UHD as its drive platform is "Pioneer RS8510" and some places say that it must be MT1959 or else don't bother. I read that if the drive name has a "U" it supports UHD and mine has. Anyway here is my drive info from MakeMKV:
Thanks in advance.
OS device name: F:
Product: BD-RW BDRUD03AS
Revision: 1.00
Firmware date: 2014-04-01
Highest AACS version: 68
Drive platform: Pioneer RS8510
Firmware version: ID23-
PM sent.Arska wrote: Tue Jun 10, 2025 6:25 pm Hello.
I've read some conflicting information about whether my drive can or cannot be made to support UHD as its drive platform is "Pioneer RS8510" and some places say that it must be MT1959 or else don't bother. I read that if the drive name has a "U" it supports UHD and mine has. Anyway here is my drive info from MakeMKV:Thanks in advance.Code: Select all
Drive Information OS device name: F: Current profile: BD-ROM Manufacturer: PIONEER Product: BD-RW BDRUD03AS Revision: 1.00 Firmware date: 2014-04-01 Bus encryption flags: 1B Highest AACS version: 68 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8510 Firmware version: ID23
Packers948
Hello - Please let me know if this Pioneer BDR-XD08UMB-S would be able to get UHD enable - Thanks
OS device name: G
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: NA
Firmware date: 2022-12-27
Highest AACS version: 77
Drive platform: Pioneer RS9331
Firmware version: ID05
OS device name: G
Revision: 1.02
Serial number: NA
No, the firmware is too new (post November 2022). You will have to wait for support, which should happen at some point in the future.Packers948 wrote: Tue Jun 10, 2025 10:14 pm Hello - Please let me know if this Pioneer BDR-XD08UMB-S would be able to get UHD enable - Thanks
OS device name: G
Revision: 1.02
Serial number: NA
Ryoga
Hello - I would like to enable Libredrive for this drive. Can someone help me to flash it ?
Informations below - thanks in advance
OS device name: G:
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.02
Serial number:
Firmware date: 2016-11-02
Drive platform: Pioneer RS8590
Firmware version: ID22
OS device name: G:
Manufacturer: ASUS
Revision: 1.02
Serial number:
No. Yours is a BD combo. Only BD writers can be flashed.Ryoga wrote: Fri Jun 20, 2025 7:54 am Hello - I would like to enable Libredrive for this drive. Can someone help me to flash it ?
OS device name: G:
Manufacturer: ASUS
Revision: 1.02
Serial number: PKDL009527WL
cinegrow
supported - original vendor firmware (Pioneer RS): 210 firmware(s):
PIONEER-BD-RW_BDR-XS05WF-1.41-B6BE50FD-8221ID25-20140402
PIONEER-BD-RW___BDR-TD05-1.00-DCD80C11-8211ID01-20120713
PIONEER-BD-RW___BDR-TD05-1.02-F9240B3B-8211-20140619Hello. Can somone confirm or not is LibreDrive work on BDR-TD05FAD? Or maybe BDR-TD05D/BDR-TD05AS?spl147 wrote: Thu Nov 09, 2023 11:22 pm does anyone have v.1.02 firmware for this drive?
label says BDR-TD05FAD
Or it's a same model? Thank you.
You need to post your Makemkv info. However, this drive will not read UHDs even if the firmware would be updated.cinegrow wrote: Sat Jun 21, 2025 11:16 pmCode: Select all
supported - original vendor firmware (Pioneer RS): 210 firmware(s): PIONEER-BD-RW_BDR-XS05WF-1.41-B6BE50FD-8221ID25-20140402 PIONEER-BD-RW___BDR-TD05-1.00-DCD80C11-8211ID01-20120713 PIONEER-BD-RW___BDR-TD05-1.02-F9240B3B-8211-20140619Hello. Can somone confirm or not is LibreDrive work on BDR-TD05FAD? Or maybe BDR-TD05D/BDR-TD05AS?spl147 wrote: Thu Nov 09, 2023 11:22 pm does anyone have v.1.02 firmware for this drive?
jiujitsuguy
Hi all! New to the 4k scene and was looking for help on getting my drive to work with UHD discs. Thanks in advance!
OS device name: E:
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 65
OS device name: E:
Revision: 1.14
Serial number:
Yeah just send that info to my email see belowjiujitsuguy wrote: Sun Jun 22, 2025 7:41 pm Hi all! New to the 4k scene and was looking for help on getting my drive to work with UHD discs. Thanks in advance!
OS device name: E:
Revision: 1.14
Serial number:
