MakeMKV not recognised?
mazzo
Post by mazzo » Tue Jun 10, 2025 8:43 pm
Hi, I put in the code for this month, and then got an error every time I tried to run it.
When I entered it, it accepted it and then crashed. Every time I try to open it it says "Fatal error occurred, programme will now exit." Every time I tried to run MakeMKV, it said the same thing and crashed.
I thought it best to delete the app, re-download it, and put in the key again, Now it's giving me a different error, saying that it could not be opened because it couldn't be verified that this isn't malware.
Can anyone help? thank you
Re: MakeMKV not recognised?
Post by dcoke22 » Wed Jun 11, 2025 11:35 am
You're probably running into macOS's Gatekeeper. There are ways to make your Mac run software that isn't notarized: https://support.apple.com/en-us/102445
The short, short version is open System Settings -> Privacy & Security -> scroll down and click the Open Anyway button
mazzo
Post by mazzo » Wed Jun 11, 2025 4:34 pm
Thank you mate. I will try to do this and see if it resolves. If not, I'll reply here again. Cheers!
Edit - that seems to have done it. Thank you kindly! :D
