Ultimate UHD Drives Flashing Guide Updated 2025
Just to clarify if I'm buying a Pioneer drive that is a 4k model and would not need to be flashed and was made in 2023..that would still work with makemkv?
Not for UHD currently. Only Pioneer drives with firmware prior to December 2022 are/can be made UHD compatible.
Sometime in the future, those with firmware from December 2022 onwards will be able to be flashed for UHD compatibility.
Oh I see thanks for the response. I guess I will hold off. I figured maybe a 4k model drive would work but oh well. Good thing I asked before buyingMartyMcNuts wrote: ↑Sat May 31, 2025 12:23 amNot for UHD currently. Only Pioneer drives with firmware prior to December 2022 are/can be made UHD compatible.
The issue is, to be able to rip UHD discs, LibreDrive mus be enabled for the drive and any Pioneer (UHD/Non UHD) with firmware from Dec 2022 onwards cannot currently have LibreDrive enabled. This is expected to happen sometime in the future.DC-2187 wrote: ↑Sat May 31, 2025 12:31 amOh I see thanks for the response. I guess I will hold off. I figured maybe a 4k model drive would work but oh well. Good thing I asked before buyingMartyMcNuts wrote: ↑Sat May 31, 2025 12:23 amNot for UHD currently. Only Pioneer drives with firmware prior to December 2022 are/can be made UHD compatible.
OS device name: E:
Current profile: CD-ROM
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E102
Serial number: ,,,
Firmware date: 2023-04-20
Firmware version: ID26
Is there way to make drive UHD compatible?
OS device name: E:
Manufacturer: ASUS
Revision: E102
Serial number: ,,,
Hi - Please let me know what LG firmware would be best for this drive WH16NS46. Thank you
MakeMkv information as below.
OS device name: G:
Product: BD-RE WH16NS46
Revision: 1.05
Serial number: NA
Firmware date: 2122-01-14 11:38
Highest AACS version: 77
OS device name: G:
Revision: 1.05
Serial number: NA
Not at this time. Firmware is too new. You need to wait until some time in the future when Pioneer drives with firmware from December 2022 onwards are supported.qnixgamer wrote: ↑Sat May 31, 2025 5:59 pmDrive Information
OS device name: E:
Manufacturer: ASUS
Revision: E102
Serial number: ,,,
Hi there,
Ive been reading through the board here and would like to ask somebody if they know whether or not my drive can be successfully flashed?
OS device name: /dev/rdisk5
Manufacturer: BUFFALO
Product: Optical Drive
Revision: BU14
Serial number: 00000000000
Firmware date: 2121-06-21 13:30
Bus encryption flags: 1F
Highest AACS version: 72
that's the info from MakeMKV info panel, it seems as if I have firmware from a hundred years in the future?!?!? some help would be most appreciated, thanks
Revision: BU14
Yes, MakeMKV shows the firmware date as 2121 instead of 2021.Jimothy wrote: ↑Tue Jun 03, 2025 8:56 pmHi there,
Revision: BU14
Yeah, you can flash it to BU40N 1.03-MK.
Would the below be able to be flashed to do UHD
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-209M
Revision: 1.10
Serial number: xxxxxxxxxxx
Firmware date: 2013-09-10
Bus encryption flags: 13
Drive platform: RS8600
Firmware version: 1.10/ID60
OS device name: G:
Revision: 1.10
Hi, I appear to have a newish (2020) drive with oldish (2017) firmware, could you advise on what (if any) firmware I can flash with to get LibreDrive functionality?
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: T*********L
Firmware date: 2017-04-18
Highest AACS version: 12
Firmware version: ID22
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
I just purchased a Verbatim 43888, because it was frequently suggested.
Can you tell me if it is flashable and which Firmware to use?
OS device name: E:
Product: BDDVDRW GGC-H20L
Revision: 1.02
Serial number: ...
Firmware date: 2007-12-27 12:34:56
Status: Possible, might be supported in future, but not likely soon
Drive platform: RS1013
Firmware version: 1.02-
OS device name: E:
Revision: 1.02
Serial number: ...
Not possible.Sam88 wrote: ↑Tue Jun 10, 2025 7:00 pmHello,
OS device name: E:
Revision: 1.02
Serial number: ...
PM sent.tyme2tb wrote: ↑Wed Jun 04, 2025 1:00 amWould the below be able to be flashed to do UHD
OS device name: G:
Revision: 1.10
PM sent.nathanm5764 wrote: ↑Fri Jun 06, 2025 9:49 amHi, I appear to have a newish (2020) drive with oldish (2017) firmware, could you advise on what (if any) firmware I can flash with to get LibreDrive functionality?
OS device name: E:
Manufacturer: ASUS
Revision: 1.10
