Hi there! Similar boat though possibly overboard... When the news about pioneer winding down their blu-ray drive manufacturing business, I knee-jerk bought 5 212Vs for future proofing... Would love some guidance on getting these UHD compatible. Thanks!
Drive 1
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DGDL028703WL
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
Drive 2
OS device name: I:
Revision: 1.02
Serial number: DGDL028702WL
Drive 3
OS device name: J:
Revision: 1.02
Serial number: DDDL027125WL
Drive 4
OS device name: K:
Revision: 1.02
Serial number: DDDL027072WL
Drive 5
OS device name: L:
Revision: 1.02
Serial number: DDDL027080WL
BDR 212V UHD Guide
Re: BDR 212V UHD Guide
Jeez! 5 drives. PM sent for all of these.PlayMeAGroove wrote: Mon Jun 09, 2025 6:51 pm Hi there! Similar boat though possibly overboard... When the news about pioneer winding down their blu-ray drive manufacturing business, I knee-jerk bought 5 212Vs for future proofing... Would love some guidance on getting these UHD compatible. Thanks!
Drive 1
OS device name: H:
Revision: 1.02
Drive 2
OS device name: I:
Revision: 1.02
Drive 3
OS device name: J:
Revision: 1.02
Drive 4
OS device name: K:
Revision: 1.02
Drive 5
OS device name: L:
Revision: 1.02
Packers948
Hello - Please let me know if this Pioneer BDR-212DBK would be able to get UHD enable - Thanks
OS device name: G:
Product: BD-RW BDR-212D
Revision: 1.02
Serial number: NA
Firmware date: 2022-03-16
Drive platform: RS8F00
Firmware version: 1.02/ID61
OS device name: G:
Revision: 1.02
Serial number: NA
PM sent.Packers948 wrote: Tue Jun 10, 2025 10:20 pm Hello - Please let me know if this Pioneer BDR-212DBK would be able to get UHD enable - Thanks
OS device name: G:
Revision: 1.02
Serial number: NA
mediacable
I purchased one of the 212V and was hoping to get some help flashing it, please + thank you!
OS device name: /dev/sr0
Revision: 1.02
Serial number: DGDL027417WL
PM sent.mediacable wrote: Fri Jun 13, 2025 2:37 pm I purchased one of the 212V and was hoping to get some help flashing it, please + thank you!
Revision: 1.02
Rudyard
Even though this is not a BDR-212V, I'd be super grateful if you could help me make this one UHD-friendly:
Current profile: DVD-ROM
Product: BD-RW BDR-209D
Revision: 1.33
Serial number:
Firmware date: 2015-12-09
Highest AACS version: 77
Drive platform: RS8600
Firmware version: 1.33/ID61
PM sent.Rudyard wrote: Sat Jun 14, 2025 6:33 pm Even though this is not a BDR-212V, I'd be super grateful if you could help me make this one UHD-friendly:
Revision: 1.33
Serial number:
Rudyard
Thanks a lot Coopervid. All set and working
BTW I always wonder if it is worth it changing the drive's read and write settings (for longevity reasons, quality of reading/writing, etc) or should I just leave them by default?
Regarding reading I let it a max. speed and Pioneers are not the fastest readers anyway for UHDs. They are limited to 4x speed.Rudyard wrote: Sat Jun 14, 2025 10:27 pm Thanks a lot Coopervid. All set and working![]()
Writing is a different animal while I don't write discs anymore at all. I store everything on HDD which is also cheaper and use a player to feed my AVR with movies. Writing 25 GB discs is also a no-brainer. However, if you want to use >= 50GB discs that is a challenge these days since disc quality has gone south and almost all have isues at the layer break. If you still want to burn these you should follow this guide that was originally posted in the Redfox forum. kitahoshi posted it here:
https://forum.doom9.org/showthread.php?t=185539&page=19
EclipseW9
Hello, I recently purchased 2 BDR-212V drives (Only one is currently installed). I recently got some UHDs and would love to enable UHD on this drive (well both drives technically).
Assuming that the drive details are the same (I haven't had a chance to install the other drive to check) Will I be able to swap out the drives and repeat the instructions, or will I need to make another request?
Here is the Makemkv drive info for the drive that's currently installed:
Thank you!
Revision: 1.02
Serial number:
Highest AACS version: 68
Firmware version: ID06-
PM sent.EclipseW9 wrote: Sun Jun 15, 2025 4:09 pm Hello, I recently purchased 2 BDR-212V drives (Only one is currently installed). I recently got some UHDs and would love to enable UHD on this drive (well both drives technically).
Here is the Makemkv drive info for the drive that's currently installed:Thank you!Code: Select all
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-212V Revision: 1.02 Serial number: Firmware date: 2022-05-31 Bus encryption flags: 13 Highest AACS version: 68 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS8F00 Firmware version: ID06
bill_w
Is it possible to flash one of these on Linux?
Perdido
Hi, like PlayMeAGroove I bought a bunch of Pioneer drives while I can, I might even get a few more later.
May I please have upgrades for these four drives:
Drive 1
Revision: 1.02
Serial number:
Drive 2
Product: BD-RW BDR-212M
Revision: 1.01
Serial number: AEDL010899WL
Firmware date: 2020-07-21
Firmware version: 1.01/ID56
Drive 3
Revision: 1.00
Serial number:
Firmware date: 2019-01-10
Firmware version: 1.00/ID61
Drive 4
Revision: 1.01
Serial number:
Grateful for the terrific help!
Drive 1
Revision: 1.02
Serial number:
Drive 2
Revision: 1.01
Drive 3
Revision: 1.00
Serial number:
Drive 4
Revision: 1.01
Serial number:
Mikin
Hello @Coopervid,
Could you please help me flash my BDR-212V to read UHD?
Here is my drive info:
OS device name: \Device\CdRom2
Revision: 1.02
Serial number: [redacted]
Best Regards
Revision: 1.02
Best Regards
