Post by SamuriHL » Sun Jun 08, 2025 5:33 pm
It's clear they "added" HDR and DV as a marketing ploy to get more people to buy it. The concept is marginally good in theory. "Own" movies before they're even released to streaming to buy much less on physical disc. And the promise of quality that rivals or surpasses disc. And I think for projector owners using SDR that's probably true especially if you combine that with a lumagen or envy. But the expense involved, lack of true ownership of your media, and quality issues of media doesn't really make it a viable platform for anyone except people with money to blow. And if you have money to blow, I'd argue you're better off with a giant NAS and physical media. Add an Ugoos to the mix and you're good to go. At least with that setup you have true ownership of the media.
Post by RESET_9999 » Sun Jun 08, 2025 6:31 pm
Plus Movies Anywhere platform might even have better quality, and the app is available on a 50$ streaming stick lol... Imagine paying 97k $ for a streaming device that has subpar encodes :lol: ...
https://slow.pics/c/n2jQBALd
19 HDR comparison of Mad Max: https://slow.pics/c/TOowwzK7
Epedemic
Post by Epedemic » Mon Jun 09, 2025 1:53 am
Epedemic wrote: Mon May 12, 2025 7:09 pm
RESET_9999 wrote: Mon May 12, 2025 4:20 pm
You will love it :)
Yes, CPM build is a must for the true tv-led option: ''source metadata''. DS workflow 3-2 will be identical to CPM HDR10+ conversion as long as you use the histogram plus.
ps check your pm, I've sent you a link to my GD RPU collection. all you need to do is inject with workflow 1.
Amazing, will definitely give the injection procedure a shot.
Can you verify I set the right settings for my use case in CPM System -> CoreELEC -> Dolby Vision?
Mode: On demand
Type: Display Led (DV-Std)
Dolvy VSVDB: Off
Colimetry: disable/remode
Source levels metadata: On
Level 5 & 6: Source
Restrict overlays: off
Preferred HDR for dual Dolby Vision and HDR10+ content: Dolby Vision
Dynamic HDR10+ to Dolby Vision profile 8.1 conversion: on
Prefer conversion over original Dolby vision: Off
Peak Brightness Source: histogram-plus
For SDR8/10: Off
For HDR10: Dolby Vision
For HLG HDR: Dolby Vision
For Dolby Vision: Off
Convert profile 7: Off
This has been running great on my setup (E6 connected through an Onkyo RZ820 AVR). But I have run into a strange problem with a few titles (O'Dessa and The Legend of Ochi webrips):
When I start playback of O'Dessa, the TV displays the DV logo, and then just goes black and displays a black screen. Not even the Kodi OSD or the volume OSD from my AVR. Audio is playing, and I can stop the video via Kore or if I hit the stop button while "blind". "The Legend of Ochi" starts to play fine, but at around 12 minutes, the screen goes black, and in this case, the picture comes back at around 22 minutes (I can skip forward to this point to get the picture back).
If I disable "Source level metadata" both files play fine. I guess there is some metadata "too complicated for the E6" that makes this happen?
I can live with turning off SLM in these (few so far) cases, should I run into other problematic media, but of course, I wonder if there is a fix, or something that can be adjusted?
Post by RESET_9999 » Mon Jun 09, 2025 11:15 am
Strange, but sounds like a source issue. Do you have a sample we can try? I never had a rip that wouldn't play on mine.
Epedemic
Post by Epedemic » Mon Jun 09, 2025 11:33 am
RESET_9999 wrote: Mon Jun 09, 2025 11:15 am Strange, but sounds like a source issue. Do you have a sample we can try? I never had a rip that wouldn't play on mine.
I would have written it off as a single source issue too, if it hadn't happened twice in a short time (if it is the same issue with both movies that is). I sent you a PM.
Post by RESET_9999 » Wed Jun 11, 2025 4:44 pm
It may not be all the Kscape titles that have color issues. I just tried another one(Poor Things) and while there is some slight difference on some frames, nothing as bad as Mad Max, Last of Us and Accoutant:
https://slow.pics/c/TzYbGpsa
ps: This is a massive comparison: 1080pBD vs KALEIDESCAPE vs Movies Anywhere vs Disney+ vs Amazon vs iTunes. 36 frames, pics are in HDR and can be viewed in HDR on Chrome/Edge.
flojo
Post by flojo » Thu Jun 12, 2025 3:32 pm
Are you all mainly looking for the ease of access to the titles? Using these planned obsolescence devices is not a wise decision, but I understand if the concern is mainly the ease of access to the titles, not the device or file properties.
I feel like someone needs to keep reiterating to newer people that if you don't need Dolby Vision Profile 7 at UHD bitrates, you can use basically any streaming device. Since most people are fine with Profile 8 at half UHD bitrates (~50GB files), a used ~20usd Amazon 4K Firestick will work fine with Kodi or NOVA Video Player (but you do need a WiFi 5+ router).
Trees
Post by Trees » Fri Jun 13, 2025 4:17 am
RESET_9999 wrote: Sat Jun 07, 2025 10:01 pm
RESET_9999 wrote: Fri Jun 06, 2025 11:10 am Well first night with the Kscape was not very good... Tried two streams: The Accountant and Last of Us S02.
Accountant:
horrible Raised black in both HDR10/DV
DV to HDR10 conversion is incorrect
1080p SDR stream different master/framing and actually better than 4K!
https://slow.pics/c/YShhgXTe
Last of us:
Doesnt look right at all, brighter than MAX webdl...
https://slow.pics/c/U1B6JARQ
the only format that seems right is SDR:
https://slow.pics/c/pZkJmdrO
OK, tested a new movie on KSCAPE, and it's the same crap. Blacks are not raised like in The Accountant, but the colors are desaturated and the brightness is not right. DV TV-LED is even worse. Compression is also slightly worse despite the much higher bitrate on KSCAPE. Definitely a terrible streaming service or device, at least for HDR10/DV, because SDR is fine.
MAD MAX DSLR Camera settings locked:
KS DV vs KS HDR10 vs Ugoos HDR10 vs G5 internal player HDR10 vs Ugoos DV
https://slow.pics/c/1aVxtAqF
lossless HDMI capture: https://slow.pics/c/ZNkOXm8g
heatmap: https://slow.pics/c/1Gx2U3Xp?canvas-mode=fit-width
Last of Us S02E01
And I've measured the whole Last of Us S02E01 episode. The KS stream(DV and HDR10) is 3 times brighter:
madvr plot(KS HDR10 vs MAX HDR10 vs MAX DV): https://slow.pics/c/OrY8Z2dl
DSLR camera (KS HDR10 vs MAX HDR10): https://slow.pics/c/pZEYwEHS
25 lossless HDMI capture: https://slow.pics/c/Z5uGaBPM
KScape HDR10 metadata are identical to the MAX web-dl:
MAX WEBDL:
The Accountant raised black
G5 KS HDR10 vs UHD-BD HDR10: https://slow.pics/c/23KldS02
Hisense TV KS HDR10 vs UHD-BD HDR10: https://slow.pics/c/nFzaM7c5
The only format that seems right is SDR:
https://slow.pics/c/eFtqwaUq
EDIT: It may not be all the titles that are affected. I tested a few more and these were ok:
https://slow.pics/c/aUX9mPSr
https://slow.pics/c/skNSEG29
Very interesting, thank you for this.
This also explains why I thought TLoU was so darn dark, Andor, too. It's not me or my TV, then. It's the silly dark HDR (C2, P5, internal player).
foxbat
Post by foxbat » Fri Jun 13, 2025 11:03 am
flojo wrote: Thu Jun 12, 2025 3:32 pm Are you all mainly looking for the ease of access to the titles? Using these planned obsolescence devices is not a wise decision, but I understand if the concern is mainly the ease of access to the titles, not the device or file properties.
If you're talking about the Kscape I think the idea is to get access to content at the highest quality possible. Unfortunately it seems that device/service does not live up to the marketing hype.
bbeny123
Post by bbeny123 » Fri Jun 13, 2025 5:20 pm
Hi RESET_9999 ,
After generating DV with cm_analyze, is it better to inject the entire new RPU or transfer all its levels to the original RPU?
You mentioned earlier that it’s possible to generate DV for P7 FEL (after prior baking).
What about P5 — is there also a way to generate DV for such movies?
Post by RESET_9999 » Fri Jun 13, 2025 7:35 pm
If it's mel, I just inject the new RPU/XML (P8)
P5: I don't know, I never tested.
Trees
Post by Trees » Fri Jun 13, 2025 7:42 pm
foxbat wrote: Fri Jun 13, 2025 11:03 am
Depends on the content, it seems. Maybe KSCAPE gets bad sources for some files, we don't know.
bluray4k
Post by bluray4k » Sun Jun 15, 2025 8:27 pm
RESET_9999 wrote: Mon Jun 02, 2025 10:24 pm once you get the webOS 2025 update, PLEX and the G4 native player should support DV MKV too.
In fact, all the TVs that are eligible for webOS 2025 should get DV MKV support.
RESET_9999, do you have more details about the webOS 2025 update? Will it enable profile 7 FEL playback via the Jellyfin or Kodi apps on my G4, meaning that I won't need to use my Ugoos AM6B+ with CoreELEC anymore? I like the Ugoos box, but having this done natively on the TV would be even better!
I tried searching for this, but your post is the only relevant result.
Yoshitaka
Post by Yoshitaka » Tue Jun 17, 2025 3:26 pm
bluray4k wrote: Sun Jun 15, 2025 8:27 pm
This would be great. I can return my ugoos if this is proven and cited.
Currently it's only playing hdr at this point in the initial set up. I'm concerned about the section highlighted in the attached image as this is where I've stopped in the video setup RESET_9999 made.
https://i.imgur.com/Dd8uyNc.jpeg
Forums are getting updated it seems like, as connection to forums is intermittent and interface look has changed.
Post by RESET_9999 » Thu Jun 19, 2025 9:55 pm
bluray4k wrote: Sun Jun 15, 2025 8:27 pm RESET_9999, do you have more details about the webOS 2025 update? Will it enable profile 7 FEL playback via the Jellyfin or Kodi apps on my G4, meaning that I won't need to use my Ugoos AM6B+ with CoreELEC anymore? I like the Ugoos box, but having this done natively on the TV would be even better!
This update will allow only P8 and P5 in an MKV container. P7 support on LG TVs was removed in 2020, and the Ugoos will be the best and only P7 player forever.
And I wouldn't use the TVs internal player for DV playback: https://slow.pics/c/IBNzcYOA
