Forced subtitles
leosantare
Forced subtitles
I understand this topic has been discussed in the past, but I was able to fully understand things looking at older threads. I've been using MakeMKV for over 10 years and just realized that forced subtitles aren't automatic. This is pretty upsetting because now I have to re-rip my entire collection.
In the example below, for the film 2012, there are 8 choices of PGS English subtitles. There are 4 choices of forced only subtitles. How do I know which one to choose, or do I just select all 4 of them? If I choose all 8, I will get forced subtitles that will appear when dialogue is spoken in other languages and subtitles for the entire film regardless of the language spoken. I can turn the subtitles on or off in VLC, but not for the forced subtitles, correct?
Thank you!
Thank you!
- Screenshot 2025-06-07 170806.png (653.42 KiB) Viewed 59505 times
Re: Forced subtitles
In general, I just select all the subtitles for my given language choice. There's no guarantee how the disc was authored so I select them all and figure it out after it is ripped. If the resulting .mkv file ends up with a forced subtitle track, I use the MKVToolNix tools to name it 'Forced Subtitles' and I mark the 'default' and 'forced' flags to true for that track in the .mkv file. It is my experience that most players then turn that subtitle track on by default when I play the movie. Player behavior will vary, but in general if you want to turn off a forced subtitle track or switch to a different subtitle track, I would expect that you would be able to do so.leosantare wrote: Sat Jun 07, 2025 9:30 pm In the example below, for the film 2012, there are 8 choices of PGS English subtitles. There are 4 choices of forced only subtitles. How do I know which one to choose, or do I just select all 4 of them? If I choose all 8, I will get forced subtitles that will appear when dialogue is spoken in other languages and subtitles for the entire film regardless of the language spoken. I can turn the subtitles on or off in VLC, but not for the forced subtitles, correct?
leosantare
Wow, that seems very complicated. I lost you when you mentioned MKVtoolnix tools and forced flags.
Is there a 4k blu ray database that tells you if a title even has forced subtitles? This way, I can at least start by figuring out which titles I need redo and which one I can leave alone. Hopefully, I only have a few titles that have forced subtitles.
Thanks,
Thanks,
leosantare
I would only be interested in the English subtitles. Therefore, you recommend I select ALL 8 English subtitle options in the example I provided, correct?
Before I decide to do this, I will only be ripping each 4k once, correct? For example, I don't do the first rip with all subtitles selected then, figure out which ones are correct and then have to go back and rip it again.
If you rip the disc once with all (English) subtitles enabled, you don't need to rip the disc a second time.
With mkvtoolnix you can enable/disable tracks, switch flags for default and forced flags, or remux the movie (= repacking with different (subtitle) tracks or a different track order without re-encoding). mkvtoolnix is a very handy tool and not that complicated to use. You should get familiar with it.
If the subtitles are the only thing missing from your rips you could also check opensubtitles.org. There is a good chance that you will find them as srt files there.
With mkvtoolnix you can add the subtitle, add the forced flag and remux the movie. Way faster and no need to put additional stress on your drive.
For future rips see viewtopic.php?t=4386 to select your preferred language(s) automatically.
In your example above, what is really selected is 4 subtitle tracks. Also MakeMKV is set such that if in any of those 4 subtitle tracks it encounters some subtitles that are marked as forced to copy those into their own separate subtitle track in the .mkv file. The resulting .mkv file will have a minimum of 4 subtitle tracks and might have up to 8 subtitle tracks. Near the end of the rip there will usually be messages in the log similar to this:
Which means MakeMKV did not find any subtitles marked as forced in a stream and therefore did not copy them into their own subtitle track in the .mkv file.
If MakeMKV does copy subtitles marked forced into their own track, it will also set the 'default' flag on that track to true. If the .mkv file is examined with MediaInfo you can see lots of details, including the state of the 'default' and 'forced' flags for various tracks. Here's an example of a subtitle track that contains forced subtitles. I used the MKVToolNix tools to set the name to 'Forced Subtitles' and to make sure that both the 'default' and 'forced' flags were set to true. Having it set this way, most players will enable this subtitle track automatically and by naming it that way, it is easy to pick out of the list if I change the subtitle track while I'm playing the file.
Here's an example of a different kind of subtitle track:
This disc had subtitles for the commentary audio track. I chose to name it 'Commentary Subtitles' so if I chose to listen to the commentary audio track and wanted subtitles, I could easily find it in the list of subtitles. In this case the 'default' and 'forced' flags are set to false or off.
I agree with Mr. Red that MKVToolNix is handy and worth getting familiar with. With that said, if you can figure out the details of a subtitle track before ripping, you can name it inside MakeMKV just like anything else and save yourself the MKVToolNix step later.
Forced subtitles track #5 turned out to be empty and was removed from output fileIf MakeMKV does copy subtitles marked forced into their own track, it will also set the 'default' flag on that track to true. If the .mkv file is examined with MediaInfo you can see lots of details, including the state of the 'default' and 'forced' flags for various tracks. Here's an example of a subtitle track that contains forced subtitles. I used the MKVToolNix tools to set the name to 'Forced Subtitles' and to make sure that both the 'default' and 'forced' flags were set to true. Having it set this way, most players will enable this subtitle track automatically and by naming it that way, it is easy to pick out of the list if I change the subtitle track while I'm playing the file.
Text #2
ID in the original source medium : 4608 (0x1200)
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 35 min 54 s
Bit rate : 3 039 b/s
Frame rate : 0.026 FPS
Count of elements : 56
Stream size : 800 KiB (0%)
Title : Forced Subtitles
Language : English
Default : Yes
Forced : Yes
Original source medium : Blu-rayCode: Select all
Text #5
ID in the original source medium : 4619 (0x120B)
Format : PGS
Duration : 3 h 24 min
Bit rate : 54.5 kb/s
Frame rate : 0.491 FPS
Count of elements : 6025
Stream size : 79.6 MiB (0%)
Title : Commentary Subtitles
Language : English
Default : No
Forced : No
Original source medium : Blu-rayI agree with Mr. Red that MKVToolNix is handy and worth getting familiar with. With that said, if you can figure out the details of a subtitle track before ripping, you can name it inside MakeMKV just like anything else and save yourself the MKVToolNix step later.
leosantare
You recommend selecting all available english, subtitle options (8 in the example I provided) when ripping a disc, correct?
Only one of the options is the forced subtitle track. However, there is no way to know beforehand which one it is. Also, some of the options may turn out to be nothing. Is this all correct?
Once I know what the forced subtitle track is after the disc is ripped, can I delete/remove all the other subtitle options I selecting from the mkv I made?
I will pay attention to what mkv says after I rip the disc and take a screenshot. If it's not too much to ask, I'm hoping you can walk me through it the first time.
I will just re-rip all my disc's again rather than add a forced subtitle track to my existing mkv's. This way, all my mkv's are done the same way.
Thank you,
Thank you,
Yesleosantare wrote: Tue Jun 10, 2025 9:14 pm You recommend selecting all available english, subtitle options (8 in the example I provided) when ripping a disc, correct?
Generally, yes, although strictly speaking one might be able to figure out which subtitle track is which before ripping. It is usually easiest to just include all relevant subtitles and sort it out later.leosantare wrote: Tue Jun 10, 2025 9:14 pm Only one of the options is the forced subtitle track. However, there is no way to know beforehand which one it is. Also, some of the options may turn out to be nothing. Is this all correct?
With the MKVToolNix tools. Or if your workflow is to make a decrypted backup of a disc first then make .mkv files from the backup, you can easily unselect the relevant subtitle tracks and create new .mkv files quickly.leosantare wrote: Tue Jun 10, 2025 9:14 pm Once I know what the forced subtitle track is after the disc is ripped, can I delete/remove all the other subtitle options I selecting from the mkv I made?
leosantare
Hey,
I only select the main feature and one audio track (the very top one) for all my discs. See screen shot. Therefore, I understand I would only ever need (2) subtitle tracks. One would be the forced subtitles, (if available) and the second for the optional subtitles. When I say optional subtitles, I'm referring to the subtitles that appear for the entire movie that I can turn on or off at any time in VLC. This can be useful for movies with hard to understand dialog. Whereas the forced subtitles only appear at certain times. I understand I can't turn off the forced subtitles in VLC. Then again, I'm not sure why anyone would want to do that.
Please let me know if I am understanding things correctly and that I would only need (2) subtitle tracks for each disc. (That's if the movie has forced subtitles. Otherwise, I would just need (1) subtitle track, the one for the entire movie.)
Yeah, I don't think I will be in the camp of knowing which subtitles to select beforehand, so I sort it out later like you said. So, by me selecting all the subtitles for each disc, I will end up with subtitles that I don't need or want. After the disc is ripped, I can remove the unwanted subtitles with MKVToolNix. I guess I don't have to remove them, they just won't serve any purpose. Either way, I like that they can be removed with MKVToolNix and will most likely want to do that.
Make a decrypted backup of the disc and a MKV file for every disc? Why would anyone want to do this, this would double the space needed for a movie collection, correct?
leosantare
Here is The Crazies 4k. Like I said, I just select the main feature (with chapters) and one audio track, the very top one. Notice for this disc there are only (2) English subtitle choices. Therefore, the one has to be the optional subtitles for the entire movie and the second for the forced subtitles. I say that because I understand this movie has forced subtitles.
If that is the case, then for this disc I just select the (2) English subtitle options and that's it? I don't have to use MKVToolNix afterwards or rename any forced flags? If that's the case, maybe I do want to learn how to know which subtitles to select beforehand for every disc. This way, I don't have to do anything afterwards.
Note, I have no idea what I'm talking about with the forced flags. I haven't gotten that far.
- Screenshot 2025-06-21 022925.png (683.42 KiB) Viewed 59025 times
Yes, exactly.leosantare wrote: Sat Jun 21, 2025 6:38 am If that is the case, then for this disc I just select the (2) English subtitle options and that's it?
With Mkvtoolnix, by activating the appropriate flag, when you watch a video file the forced subs will automatically be displayed, otherwise you will have to do it manually. In fact, with Mkvtoolnix you can do many things, for example if you have multiple audio languages, choose which one should be the default. It saves all changes to a new video file by renaming it, it does not overwrite the original video file. Using Mkvtoolnix is very easy and intuitive.leosantare wrote: Sat Jun 21, 2025 6:38 am I don't have to use MKVToolNix afterwards or rename any forced flags? If that's the case, maybe I do want to learn how to know which subtitles to select beforehand for every disc. This way, I don't have to do anything afterwards.
However, in general, as you have already been told, when you rip a disc select all the subtitles of the language you want (in your case English). Then you check which ones are forced, which, if you do not know they are there, may not even be there. You can check which ones are with VLC or with Subtitle Edit, for example.
You could also extract the subtitles (on Linux I use mkv-extractor-qt) and convert them to another format (with Subtitle Edit and OCR), because for example you have an old player connected to the TV that does not read PGS subs.
I don't keep the backup folder; I only keep the resulting .mkv files. Making the decrypted backup allows me to separate the reading of the optical disc from the part where I sort through what's on a disc. Creating .mkv files from a backup is functionally the same as creating them directly from the optical disc, although creating them from a backup usually takes much less time.leosantare wrote: Sat Jun 21, 2025 6:25 am Make a decrypted backup of the disc and a MKV file for every disc? Why would anyone want to do this, this would double the space needed for a movie collection, correct?
For example, if I buy a new movie, I can bring it home and spend only a minute or two starting a backup and not worry about how long it takes to read the disc. It doesn't matter that a few days pass before I have time to actually sort through the disc and make proper .mkv files. After I'm satisfied with my .mkv rips, I delete the backup folder.
The other useful side effect of this strategy is I find out right away if the disc is defective and can return or exchange it during the return window.
A lot of Blu-ray movies/tv shows are 1 big .m2ts file per movie/episode, so keeping a complete disc image is only a burden for players that you can't make a single file playlist for. Granted some disc images are chunked .m2ts files, like the UHD of Gladiator 2000, but these discs seem to be an extremely low percentage.
leosantare
If I do what you do, make a backup first, how do I make the backup and would I still need to use MKVToolNIX at some point? Also, what do you mean by you make mkv files from a backup? Are you saying you make more than one mkv for each disc? I only want to make one mkv file per disc.dcoke22 wrote: Mon Jun 23, 2025 4:21 pmI don't keep the backup folder; I only keep the resulting .mkv files. Making the decrypted backup allows me to separate the reading of the optical disc from the part where I sort through what's on a disc. Creating .mkv files from a backup is functionally the same as creating them directly from the optical disc, although creating them from a backup usually takes much less time.leosantare wrote: Sat Jun 21, 2025 6:25 am Make a decrypted backup of the disc and a MKV file for every disc? Why would anyone want to do this, this would double the space needed for a movie collection, correct?
I understand ALL discs have optional subs for the main feature. I also understand that not all movies have forced subs, is this correct?
Like I said, I only select the main feature and one audio track (the very top one) for all my discs. See screen shot. Therefore, I understand I would only ever need (2) subtitle tracks.
Is this correct?
One would be the forced subtitles, (if available) and the second for the optional subtitles. (When I say optional subtitles, I'm referring to the subtitles that appear for the entire movie.)
Is this correct and can I turn the optional subtitles on/off in VLC?
Can the forced subtitles be turned on/off in VLC?
Again, I'm just looking to make one mkv per disc with the (2) subtitle tracks described above. If the movie doesn't have any forced subtitles, it would just be the (1) optional subtitle track. As you mentioned more than once, it is impossible to know which (1-2) subtitles tracks to select for every disc. Therefore, I need to select all available subtitles options for each disc. This will result in having some unnecessary/unwanted subtitle tracks for some of my mkvs. Personally, I would want to remove these unnecessary/unwanted subtitle tracks for OCD reasons after the fact, with MKVToolNix. However, is it even necessary?
I'm just trying to decide which way I want to do this before I start.
Even though you ignored me before, I'll take the liberty of answering you too, even though the questions are addressed to dcoke22, I just wanted to help you.
dcoke22 rips the entire disk to hdd/ssd (makes the backup) with the appropriate option in MakeMKV, then later creates the movie in .mkv always with MakeMKV, but using the backup and no longer the physical disk, and once done it erases the entire disk (the backup) that it ripped first to hdd/ssd. I've done this myself sometimes, so as not to stress the optical drive, for example if I change my mind and want to save more than one language, or if I'm afraid of forgetting a subtitle.
But like dcoke22, I sometimes do this to find out if a newly purchased Bluray is free of problems.
And as far as VLC goes, you can turn them on/off.
And with VLC you can choose, as mentioned, to deactivate them all or activate the ones you want. Then if you want to do a job well done, then in this case you use Mkvtoolnix, and choose which subtitle you want by default, or eliminate the superfluous ones, you can do whatever you want.
Frankly, I don't see what problems there are.
Mkvtoolnix is used if you want to modify something or more things in the .mkv file, otherwise it is not necessary.leosantare wrote: Tue Jun 24, 2025 2:15 amIf I do what you do, make a backup first, how do I make the backup and would I still need to use MKVToolNIX at some point? Also, what do you mean by you make mkv files from a backup? Are you saying you make more than one mkv for each disc? I only want to make one mkv file per disc.dcoke22 wrote: Mon Jun 23, 2025 4:21 pmI don't keep the backup folder; I only keep the resulting .mkv files. Making the decrypted backup allows me to separate the reading of the optical disc from the part where I sort through what's on a disc. Creating .mkv files from a backup is functionally the same as creating them directly from the optical disc, although creating them from a backup usually takes much less time.leosantare wrote: Sat Jun 21, 2025 6:25 am Make a decrypted backup of the disc and a MKV file for every disc? Why would anyone want to do this, this would double the space needed for a movie collection, correct?
Yes, I already told you in my previous post that you ignored.leosantare wrote: Tue Jun 24, 2025 2:15 am I understand ALL discs have optional subs for the main feature. I also understand that not all movies have forced subs, is this correct?
If I understand the question correctly, and if you are referring to the image in the first post, it is better to select all the subtitles in your language, because you do not know which ones are forced.leosantare wrote: Tue Jun 24, 2025 2:15 am Like I said, I only select the main feature and one audio track (the very top one) for all my discs. See screen shot. Therefore, I understand I would only ever need (2) subtitle tracks.
Is this correct?
But how many subtitles can there be in a movie? If you only save those in your language, and let's say that in addition to the main and forced ones, there are also those of any comments on the movie, for example from the director or actor: will there be 3-4 in total? They don't seem like a lot to me.leosantare wrote: Tue Jun 24, 2025 2:15 am Again, I'm just looking to make one mkv per disc with the (2) subtitle tracks described above. If the movie doesn't have any forced subtitles, it would just be the (1) optional subtitle track. As you mentioned more than once, it is impossible to know which (1-2) subtitles tracks to select for every disc. Therefore, I need to select all available subtitles options for each disc. This will result in having some unnecessary/unwanted subtitle tracks for some of my mkvs. Personally, I would want to remove these unnecessary/unwanted subtitle tracks for OCD reasons after the fact, with MKVToolNix. However, is it even necessary?
