PIONEER BDR-209 change the Firmware ?
jiromimo
Bonjour à tous.
Je possède 1 lecteur PIONEER - BD-RW BDR-S09 - Révision : 1.51 - de 08 - 05 - 2018 - encryptage bus : 1B - AACS la plus haute : 20 -
LibreDrive Information: Status: Enabled - Drive platform: RS8600 - Firmware name: PIONEER BDR-209 - Firmware type: Original (unpatched) -
Firmware version: 1.51/ID43.
Puis-je changer le Firmware ?
Cordialement
Hello everyone.
I have 1 PIONEER player - BD-RW BDR-S09 - Revision: 1.51 - from 08 - 05 - 2018 - bus encryption: 1B -
AACS highest: 20 - LibreDrive Information: Status: Enabled - Drive platform: RS8600 -
Can I change the Firmware ?
Best regards
Cordialement
Hello everyone.
Best regards
Re: PIONEER BDR-209 change the Firmware ?
PM sent.jiromimo wrote: Fri May 30, 2025 5:45 pm Bonjour à tous.
Cordialement
Hello everyone.
Best regards
vander
Hello
I have a similar drive:
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-209D
Revision: 1.51
Serial number: ...
Firmware date: 2018-05-08
Bus encryption flags: 13
Firmware version: 1.51/ID61
There is one user (BassGuitarRox) who reported that flashing this drive (BDR-209D) led to unpredictable behaviour (Of course this may have been a hardware issue). I'm keen to try flashing my drive but slightly apprehensive about messing the drive up - it currently works perfectly for Bluray backups, just doesn't see 4K disks.
Would be grateful for advice.
OS device name: I:
Revision: 1.51
Serial number: ...
PM sent.vander wrote: Sat May 31, 2025 10:55 pm Hello
OS device name: I:
Revision: 1.51
Serial number: ...
jiromimo
Merci pour le retour, VANDER,
Quel serait le FIRMWARE le plus approprié pour ce PIONEER BDR 209 ?
Cordialement
Cordialement
You should read your PM!!!!jiromimo wrote: Tue Jun 03, 2025 4:05 pm Merci pour le retour, VANDER,
Cordialement
Boaty67
Hi Coopervid,
Would you be able to help me too? I also have a similar drive. Details below:
Revision: 1.34
Serial number:
Firmware date: 2016-04-25
Highest AACS version: 78
Firmware version: 1.34/ID61
Revision: 1.34
Serial number:
PM sent.Boaty67 wrote: Wed Jun 04, 2025 5:26 pm Hi Coopervid,
Revision: 1.34
Serial number:
tape85
Hello all together,
I also bought this drive, can I receive am PM, too?
Thanks in advance,
tape85
Thanks in advance,
tape85
You need to post your Makemkv info.tape85 wrote: Fri Jun 06, 2025 6:43 am Hello all together,
Thanks in advance,
tape85
cbnbmore
OS device name: H:
Product: BD-RW BDR-S09
Revision: 1.31
Serial number:
Firmware date: 2015-05-25
Highest AACS version: 82
Firmware version: 1.31/ID43
It appears others have been able to make these drives UHD capable. I'd appreciate any help. Thanks.
OS device name: H:
Revision: 1.31
Serial number:
jiromimo
Bonjour,
C'est quoi MP ?
Vous devriez lire votre MP.
ou MP envoyé.
Cela veut dire quoi ?
Cord
C'est quoi MP ?
ou MP envoyé.
Cord
Google Translate wrote:Hello,
What's a PM?
You should read your PM.
or sent PM.
What does that mean?
Cord
"PM" refers to "Private Message", a function of the board. New users cannot send them, but may receive them.
Login and read yours. If not read within 14 days I will delete it.jiromimo wrote: Tue Jun 10, 2025 4:43 pm Bonjour,
C'est quoi MP ?
ou MP envoyé.
Cord
What's a PM?
or sent PM.
Cord
ravs74
Hi All,
Also have a Pioneer BDR-209D which reads Blu-Rays OK, but cannot open 4K UHD discs.
Below is the drive information from MakeMKV:
Revision: 1.10
Serial number: MIDL000214WL
Firmware date: 2013-09-10
Highest AACS version: 76
Firmware version: 1.10/ID61
Would appreciate any help on how to update the drive for 4K blu-rays
Revision: 1.10
